20 Most Recent
Blu Zoey T176 Mobile Phone Questions & Answers
How to remove the back on a blu zoey t 176?
The back cover is clipped not screwed so you need to pry something between sideways and up. I use my thumbnail to do it. It is tight fitted to avoid moisture and a new one would have a little difficulty. Hope this works.
How to navigate to factory reset?
Factory resetting it may still return you to Spanish as it's default language or even worse enough, Chinese. You can download language translator on another phone,PC or tablet as your guide to reset it to your language of choice. Do it this way, translate, menu,settings, language setup into Spanish and follow them on your phone to navigate to change the language.
SD Card can not be recognized on the phone
Blu phones have a history of not being able to read music. Make sure they are in MP3 format. Not WAV, MP4, etc. If you need more help, please do not hesitate to let me know!
-Mr. W
Can i enter a mutiple number contact?
yes you can on most cell phones. try using pressing and holding the * key for a moment and it should put a comma(or a P) after the last # (this is a 1-2 second pause), then just key in the next numbers you want. (if you need more time between numbers, just insert more Pauses.)
i.e. 18005551212,1,12223334444
this would make it dial 18005551212 then wait 2 seconds,
then dial 1(to leave a callback number), wait 2 seconds,
then dial 12223334444 (your callback number).
some phones put a limit on how many numbers can be dialed with a contact...but you should be able to put most numbers in. i use this method myself.
