20 Most Recent
Belkin WeMo Insight Switch Questions & Answers
My wemo insight switch quit working. Wemo does not answer my emails. How to I remove the Insight switch but not delete my wemo light switch?
Restart the Wemo Insight Switch:
Sometimes a simple restart can resolve connectivity issues. Unplug the Wemo Insight Switch from the power outlet, wait for about 10 seconds, and then plug it back in. Observe if it responds after this.
Update the Wemo App:
Ensure that you have the latest version of the Wemo app installed on your phone. Outdated apps can sometimes cause communication problems with the devices.
Check Your Wi-Fi Network:
Confirm that your Wi-Fi network is functioning correctly. Since you mentioned that you've already checked your Wi-Fi, let's move on to the next steps.
Factory Reset the Wemo Insight Switch:
If the switch remains unresponsive, consider performing a factory reset. This will remove any stored settings but won't affect your other Wemo devices.
Here's how to do it:
Press and hold the small tab at the bottom of the Insight Switch for 10 seconds until the light blinks red.
Wait for the light to blink blue again, indicating that the switch is ready to be paired with the Wemo app.
Connect the switch to your 2.4 GHz Wi-Fi network (not the 5 GHz network, as the switch isn't compatible with the latter).
Re-Add the Wemo Insight Switch:
After the factory reset, set up the Insight Switch again using the Wemo app. You'll need to provide a custom name and picture for it.
During the setup process, make sure to select the correct Insight Switch and not accidentally remove your Wemo light switch.
Contact Belkin Support:
If none of the above steps work, I recommend reaching out to Belkin's customer support. While email hasn't been responsive, you can try other channels such as their official support website.
Just need the instruction manual
Here is a link to one of them - http://www.springfieldprecision.com/wp-content/themes/starkers/style/manuals/manual-91455sfd.pdf - you can replace the model with your specific model to see your manual. The site doesn't work correct to do a search. Hope this helps.
