20 Most Recent
Samsung Galaxy Note 10.1 2014 Edition, 16GB, Wi-Fi, white Questions & Answers
How to delete music from samsung 2014 edition tablet
If these are on the device and not a SD card & it works like a traditional Android device, you probably have two options; you can use a file manager app, go to the directory and manually delete them right from there. You can also plug the device into your computer, go to the directory where the music is (my non-samsung device has a folder labeled 'Music'), remove them that way and even add other music. I dont know if Samsung still wants you to use their program called Kies; their version of a iTunes like file manager; it may have the drivers you need for your computer to recognize the tablet, you can download it from their site usually, but on my older Samsung device, once my computer had the drivers it needed,s I just used my computers file manager to add and remove media.
If you have put these on a SD card, just shut off the device, remove the card, and put in a card reader attached to your computer and move things around at will.
Why does my Galaxy tablet not switch on
have you tried holding the on button and power up button at the same time for about 30 sec to a minute. If this does not work, verify that you are charging with the original power plug or one of the exact same type.
My ivso bluetooth keyboard does not hold its charge. What could be the issue and how do I fix it?
- Battery issue: The battery in the keyboard may be faulty or have a low capacity, which can cause it to quickly drain and not hold a charge.
- Charging issue: The charging port or cable may be damaged, preventing the battery from charging properly.
- Keyboard software issue: There may be a software issue with the keyboard that's preventing it from charging correctly or retaining a charge.
- Connectivity issue: The keyboard may not be compatible with your Samsung tablet, or there may be a Bluetooth connectivity issue that's causing the battery to drain quickly.
It is recommended to have the issue diagnosed by a qualified technician or customer support for the keyboard manufacturer. They can diagnose the issue and provide a solution to resolve the problem. Ignoring the issue could lead to further damage and increased repair costs in the future.
