20 Most Recent Panasonic KX-FHD332 Plain Paper Thermal transfer Fax Questions & Answers
0answers
0answers
0answers
Phone company added a dedicated fax line to the
Your wall outlet has four wires, the center two are the first line and the outside two are the new fax line. You need to go to Radio Shack and get an adapter to split your first and second line into two separate wires. The part number is below.
Steren® 2-Line 4-Conductor Splitter/Adapter (Ivory) pixel.gifModel: T07843 | Catalog #: 55034722
4/19/2010 2:16:16 PM • Panasonic... • Answered on Apr 19, 2010
Caller ID problem with KX-FHD332
Your fax machine does not actually have CALLER ID, it reads what the sending fax machine has programmed into it. If it was never entered in, you won't see it.
1/14/2010 4:36:49 PM • Panasonic... • Answered on Jan 14, 2010
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
9/19/2009 11:37:27 AM • Panasonic... • Answered on Sep 19, 2009
How can I turn off the auto answer feature of the
Set the fax machine to Telephone mode by pressing
{RECEIVE MODE} until TEL MODE is
displayed.
You might also want to dowload the Operating Instructions for you fax machine: KX-FHD332 Operating Instructions (English) (17208 kb)
8/4/2009 2:02:32 AM • Panasonic... • Answered on Aug 04, 2009
Panasonic fax kx-fp153
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
6/11/2009 3:33:54 PM • Panasonic... • Answered on Jun 11, 2009
Is there a way to re print a sent fax?
No there is not. You either have to fax them back requesting new copy
6/6/2009 4:34:02 PM • Panasonic... • Answered on Jun 06, 2009
Fax memory full message
Try unplugging the power cord for 30 seconds.
3/17/2009 11:28:47 PM • Panasonic... • Answered on Mar 17, 2009
Phone line reversed
The tip and ring (red and green) wires in the phone line are the ones that are used in this instance and there is technically no polarity (+ or -) because the current on this line is AC. Much like household current most device will work no matter which way the plug is inserted. There are polarized plugs which only work one way just to keep everything standard. Long story short: this should not be a problem under normal conditions.
1/22/2009 3:45:02 AM • Panasonic... • Answered on Jan 22, 2009
It will not start printing,or exept printing or copying
Try unplugging the power cord and re plugging in.
If it rings but won't pick up, you may be set for MANUAL mode.
9/26/2008 11:33:53 PM • Panasonic... • Answered on Sep 26, 2008
Incoming documents are too dark
Your thermal head seems to be going bad. No fix for it.
Are they dark when you make a copy?
9/26/2008 11:32:22 PM • Panasonic... • Answered on Sep 26, 2008
Panasonic KX-FP153 Copy too dark
Try unplugging the power cord and re-plugging. It sounds like your scanner assembly is going bad.
9/26/2008 11:30:12 PM • Panasonic... • Answered on Sep 26, 2008
HOW TO RECIEVE FAX ?
Try unplugging
8/31/2008 12:34:51 AM • Panasonic... • Answered on Aug 31, 2008
Paper Jam
Try unplugging.
8/31/2008 12:34:06 AM • Panasonic... • Answered on Aug 31, 2008
Memory full
This machine should actually print the stored jobs when you have paper in it. It may have a job in memory that is to large for the memory, if that is the case it would need to be cleared by turning the machine off and on.
You may also want to go to Panasonics website and look at the user manual for this machine as well.
1/17/2008 9:41:59 PM • Panasonic... • Answered on Jan 17, 2008
Panasonic KX-FHD332 Plain Paper Thermal transfer Fax Logo
Popular Tags
33 questions posted
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Office Equipment & Supplies
Most Popular Question
phone company added dedicated fax line
  • Office Equipment & Supplies
