20 Most Recent
Panasonic FP-D250F Copier Questions & Answers
Panasonic error code E01-22 Model
The main causes of this error are mentioned below :-
An E01-22 error means something wrong with the 'polygon motor synchronization'.
1- engine pcb
2- laser unit
3- lvps [low voltage power supply]
4- sc pcb
A question about the problem: does the machine make a loud buzzing
sound when its power is on / turned on ? if so, the motor itself or its
bearings could be the problem.
For your information, the polygon
motor is part of the laser unit, usually... it rotates a mirror that
deflects the laser beam repeatedly across... elements in the machine of
no concern right now. Being part of the laser unit subassembly, most
often, if it is really defective it can require an (expensive)
replacement (the laser unit usually costs a fair amount and cannot be
disassembled for repair owing to containing many delicate /
adjustment-requiring parts.)
So, do the very thorough cleanout
first for sure... sometimes the mirror on the polygon motor, that
deflects the laser beam, that has to go through a glass before hitting
the drum, is fogged or something, but the glass it has to go through is
cleanable and should in such a case be cleaned for sure! to see if
that's the problem.
And there's always the hard reset, to try:
Turn the copier OFF, when it is on, by suddenly and sharply unplugging it from the power source.
Leave it that way for 10 minutes.
Plug it back in.
Turn it on if it didn't turn itself on. Wait for it to initialize.
Try copying again.
Be advised that there could be few probabilities for the above error.If i would be in your place, i would rather call a tech and take care of it rather than buying laser unit and hope that it would resolve the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
3/3/2011 5:58:49 PM •
Panasonic...
Answered
on Mar 03, 2011
E1-22 indicates a problem with the Polygon Motor Sychronization....this is a problem in the laser unit either the Driver pcb is shorted or broken, the Laser unit pcb is defective, the laser unit itself could be defective.
11/8/2010 5:38:35 PM •
Panasonic...
Answered
on Nov 08, 2010
CLOSE ADF WHEN A SHEET IS PUT INTO IT
There is a switch under the ADF check and make sure that switch is engaged when ADF is closed
Switch is located in the Middle of ADF right above the ADF Sensor on the machine platen glass
4/14/2010 11:37:41 PM •
Panasonic...
Answered
on Apr 14, 2010
Panasonic FP-D250 with E05-55 code
E05 errror means laser motor synchronization. In such scenarios you need to replace laser unit. The part number for the same is FFPGC0208 .
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
2/3/2010 9:55:52 PM •
Panasonic...
Answered
on Feb 03, 2010
Error 01-22
Have you check the cable connection between the Print Head (Laser) and the main board? The code is for motor inside the printhead. You replaced the print head? and it did not fix it? Esure the cables when reconnected properly installed. Mite want to reseat the cables. Main Board would be next:( Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
8/23/2009 2:18:26 AM •
Panasonic...
Answered
on Aug 23, 2009
