20 Most Recent
Panasonic FP-7760 Copier Questions & Answers
I HAVE A PANASONIC FP-7760 THAT SHOWS ERROR CO1OO.
C0100 indicates a problem with the PC Drum charge wire cleaning motor(M21's) failure to turn.
M21 is the motor attached to the corona unit itself...you will see this when the drum unit is slid out of the copier.
11/8/2010 5:28:36 PM •
Panasonic...
Answered
on Nov 08, 2010
PANASONIC DP C322
try another, the reset mechanism on the drum is not working. drum is good, technician will have to reset
3/30/2010 2:40:57 PM •
Panasonic...
Answered
on Mar 30, 2010
Error message
if the door is closed unplug and plug the unit back in if that doesnt work you have a defective switch
4/30/2009 4:17:25 PM •
Panasonic...
Answered
on Apr 30, 2009
Duplex unit
Open all the tray's and paper bins and exit bins and check for even a little piece of paper
1/21/2008 4:36:50 PM •
Panasonic...
Answered
on Jan 21, 2008
Panasonic KX-MB2025 Toner Low Problem???
Does the machine say replace drum or toner. Two different units. If toner did refill or install a new toner. There is a chip on most drums and toner to tell the machine they are new. if you refill the toner the chip is still going to tell the machine it is used.
Panasonic DP-C266 does not print one color
If your Panasonic DP-C266 copier is not printing yellow and you have already attempted some troubleshooting steps, here are a few additional suggestions to consider:
- Verify Toner Cartridge: Confirm that the yellow toner cartridge is installed correctly. Ensure it is securely inserted into the copier and that any protective seals or tabs have been removed from the cartridge.
- Check Toner Levels: Check the toner levels of the yellow cartridge. If the toner is low or depleted, replace the cartridge with a new one. Even if the toner appears to be full, it's possible that the cartridge may be defective or experiencing a blockage.
- Clean Developer Unit: The developer unit may have accumulated debris or become contaminated, leading to poor toner transfer. Open the front cover and locate the developer unit. Carefully remove it and clean it according to the manufacturer's instructions. Use a soft, lint-free cloth to remove any toner or debris. Avoid touching the developer roller with bare hands.
- Check Drum Unit: The drum unit may be damaged or worn, resulting in the poor transfer of yellow toner. Inspect the drum unit for any signs of damage, scratches, or wear. If necessary, replace the drum unit with a new one.
- Perform Color Calibration: Use the copier's built-in color calibration feature to ensure accurate color reproduction. Refer to the user manual for instructions on how to access and perform color calibration. This process can help correct any color imbalances.
- Service or Professional Help: If the issue persists after trying the above steps, it may require professional assistance. Contact Panasonic customer support or schedule a service visit by a qualified technician. They have the specialized tools and knowledge to diagnose and address specific issues with your copier model.
When contacting customer support or a technician, provide them with detailed information about the problem, including the steps you have already taken for troubleshooting. This will help them in providing more accurate assistance and guidance tailored to your specific situation.
