20 Most Recent
Panasonic Workio DP-2500E Copier Questions & Answers
Workio DP 2500
means that the machine needs a good cleaning because it reached so many copies. has to be serviced by a dealer
Error E01-22 - Check Printer on my DP-2500
"E1-22"
5th & 6th mirror assy. sensor problemMirrors are out of position, was someone cleaning the mirrors or touched for it for a reason??? if not the sensors are bad
My kyocera 1500 is only copying part of the page.
check and see if what you are printing and the paper are the same sizeseven if you are printing LTR or A4 and the machine has LTRR or A4R it will cut the copy also check the paper tray size switches
Lines on copy
If using feeder, u need to check whether scanning mirror is dirty or not.
To identify drum problem, u can print out function list or total
counter from the machine or check whether lines appear on the drum.
If drum is not seriously worn out, u can use solutions such as Mr. Mckenic Contact Cleaner to clean the drum.
If still cannot, u have no choice except replace the drum...
HELP FIXING ERROR CODE E04-01
you may go for the min time to service mode (funtion+orginal size A3+3), F9 mode, ram initialize, then find LBP FUSER RESET. then restart your machine. your lamp, thermistor, fuse , power supply all may be bad. you should get them tested
E04-01 CHECK PRINTER
Welcome to Fixya
Error E04-01 Means Fuser problem. You may try to reset the printer by following the procedure below:
press function + orig. size + 3
press 9
find ram initialize
note: make sure that LBP FUSER RESET is the selected one
press set.
If you still encountered an e4 error, it means that there is a physical/hardware problem on your fuser unit.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
E04-01
e04-01 indicates a fuser problem...possibly fuser lamp, thermister, or thermostat.
Panasonic DP 2500 photocopy machine from you a few
the top cover that opens to the left normally has a small piece of plastic that slots into a sensor toward the back of the adf. this small piece has broken off so the machine thinks the adf is open. an engineer would need to replace the door for you.
