20 Most Recent Panasonic RN-202 Handheld Cassette Voice Recorder Questions & Answers
use a mono cable on the output or headphone side of the one playing the tape to the microphone input on the other,make sure you have the volume set right on the one playing the tape for better clarity
Panasonic RN-202... | Answered on Apr 28, 2010
You need to tunr the power off at the wall socket. Leave the unit off for at least 5mins. Then whilst holding the power on button on the unit down, turn the power back on at the socket, keep the power button depressed for at least 5secs. When you release it you should see -----------------, in the display. The unit has just been reset to factory mode. All features should now be present again. Hope this helps.
Panasonic Audio... | Answered on Sep 16, 2019
Applicable codes will be found in the remote control, if it is compatible.
Panasonic Audio... | Answered on Sep 15, 2019
Go to this page and search your model
number
https://www.panasonic.eu/downloads/en_GB/popup.html
Panasonic Audio... | Answered on Sep 11, 2019
Connect weaker wires between speakers and receiver. Positive to positive and negative to negative for best sound.
Connect turn table RCA jacks to receiver PHONO input, L & R.
Connect devices to power and set receiver to PHONO, go.
Panasonic Audio... | Answered on Jul 05, 2019
Contact the authorized service center for Panasonic.
Hello Zubair, to connect your phone to the SA-AK 67, you need a cable that has two RCA connectors (White and Red) to a 3.5mm stereo jack
The RCA connectors, you connect them in the AUX input that is on the rear panel of the SA-AK67 and the 3.5mm stereo jack, in the headphone output of your phone
You select Aux on the Panasonic, you play something on your cell phone and you're done
I hope you find the information useful
Greetings Franco Dosil
Hola Zubair, para conectar tu tel?fono al SA-AK 67, necesitas un cable que tenga dos conectores RCA (Blanco y Rojo) a una ficha 3,5mm est?reo
Los conectores RCA, los conectas en la entrada AUX que esta en el panel trasero del SA-AK67 y el conector 3,5mm est?reo, en la salida de auriculares de tu tel?fono
Seleccionas Aux en el Panasonic, reproduces algo en el celular y listo
Espero te sea util la informacion
Saludos Franco Dosil
http://www.usersmanualguide.com/panasonic/cd_stereo_system/sa-ak57 http://www.usersmanualguide.com/panasonic/cd_stereo_system/sa-ak77
Panasonic Audio... | Answered on Jul 03, 2019
Hello Jeffrey, to be able to listen to your portable cassette player in the sound system of your car, you can use the audio converter 3.5 mm to USB
I sent you the link of a video, so you can see what I'm talking about
I hope you find it useful
Hola Jeffrey, para poder escuchar tu reproductor de cassette port?til en el sistema de sonido de tu auto, puedes usar el conversor de audio 3,5 mm a USB
Te env?o el link de un v?deo, para que veas de lo que te hablo
Espero te resulte ?til
Panasonic Audio... | Answered on Jul 02, 2019
Hello Cal, I sent you the link to download the service manual for your Panasonic
I hope you can place the clip
Hola Cal, te envio el link para que descargues el manual de servicio de tu Panasonic
Espero puedas colocar el clip
https://elektrotanya.com/panasonic_rf-2400_html_sm.zip/download.html
https://www.manualslib.com/download/649026/Panasonic-Rf-2400.html
Hello William, I sent you the link to download the user manual of your SA PT 70
I hope you can solve your concern
Hola William, te envio el link para que descargues el manual de usuario de tu SA PT 70
Espero puedas resolver tu inquietud
http://panasonic.ae/en/manuals/SC-PT75.pdf
Panasonic Audio... | Answered on Jun 14, 2019
I DON'T KNOW. PLEASE PLUG SOMETHING ELSE INTO YOUR OUTLET TO MAKE SURE THERE IS ELECTRICITY THERE. UNLIKELY BUT LED MAY NOT BE WORKING. THIS LINK MAY BE OF ASSISTANCE WITH YOUR CONNECTIONS <https://www.manualslib.com/manual/119573/Panasonic-Sa-Ak770.html>
Panasonic Audio... | Answered on Jun 10, 2019
Panasonic RN-202 Handheld Cassette Voice Recorder Logo
2 questions posted
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Audio Players & Recorders
Most Popular Question
recording from one handheld cassette
  • Audio Players & Recorders
