20 Most Recent
Sony VPL CS1 Multimedia Projector Questions & Answers
Horizontal Green Lines!
Hi Tim
I've seen this many times. Only way to get rid of it is to replace the Mainboard.
This will get worse as time goes by.
Lamp/cover light blinking
Myn is a Sony 3LCD and it has just let me and game funs down ;Imagine Chelsea Vs Man U and this gadget projector won't turn on,th hall is full and my oh, the lamp cover buttorn fflashng and no light,, a zbiig let ddown
Turns off fan blinks yellow
Check and replace the fan. Check the fan regulator electronic circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box.
Shuts off fan blinks yellow
It sounds like your bulb has expired and needs to be replaced. Here's a link to a free manual which explains how to replace bulb.
http://pdf.crse.com/manuals/4074278111.pdf
My Sony VPL CS1 projector was working on Monday
hi,
check the lamp cover is it open or not. there is switch for sensing, is the lamp cover is open or not. may be it became faulty. also check the lamp is it burned or not . if found burned replace it.
ok
When the projector warms up
It is possible that your projector has the syncronisation fault in the video processor section. There is a possiblity that the chip is faulty or the corresponding allied cirrcuits have sprung up with some passive component weakness. What you can do is to open the set and warm up the areas near the main chip . Switch on the projector and if you notice the roll had stopped try do it to specific components and finally to the main IC .Replace when you are confirmed but attempt only if you are experienced or seek help to replace. Hope this helps. Good day
Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
Projector SONY VPLCS!
I had the same problem with a Sony VPL CS1. It's not the mainboard, but the blue filter - cost to repair runs around $500 US.
Hope that helps.
No image when Windows loads up, image OK before the windows starts
Hi there
Check that your resolution on your PC matches that of your Projector.
i.e : If your Projector is XGA ( 1024x768 ) that should be the resolution of your PC as well.
To change your resolution on your PC simply right click on your desktop and go to properties and then settings. You'll see the resolution bar in the middle.
