20 Most Recent ASUS K52F-BBR5 Notebook Questions & Answers
2answers
Bios password unlock
Contact Asus for a one-time BIOS password.
2/20/2019 2:19:48 PM • ASUS K52F-BBR5... • Answered on Feb 20, 2019
Cannot get Farmvill2 by Zynga to download on my computer.
I'd try clearing your browsers cache/history. Doing this is quite easy. If you follow along with this WikiHow article, it'll walk you through doing it on any current day browser (Internet Explorer, Chrome, Firefox, Safari). Doing this usually helps speed browsers up, and can help with troubleshooting performance issues with online content. http://www.wikihow.com/Clear-Your-Browser's-Cache Keep in mind, this usually also resets your browsing history. If you have any sites that aren't saved by bookmarking them, I'd recommend doing that before proceeding with the clearing. After doing this, try running the game again from Zynga's website. Hope this helps!
8/25/2014 7:28:47 AM • ASUS K52F-BBR5... • Answered on Aug 25, 2014
0answers
Verry slowly
what driver ?
1/15/2014 3:07:44 PM • ASUS K52F-BBR5... • Answered on Jan 15, 2014
My asus k52f built in webcam will not work
Try reinstalling the WEBcam driver. You can download the WEBcam and device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
11/9/2013 5:28:07 AM • ASUS K52F-BBR5... • Answered on Nov 09, 2013
Asus k52f laptop says missing operating system after restore
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
4/2/2013 6:19:17 AM • ASUS K52F-BBR5... • Answered on Apr 02, 2013
How to uninstall k52f asus bios laptop administrator user password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type DEBUG and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type: o 70 2e which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type: o 71 ff and hit Enter. Finally type: Quit and hit Enter one last time to quit DEBUG back to the C:\> prompt. Now you're ready to reboot your PC, and press the appropriate key or key combo (look it up in your motherboard manual if you don't know it) to access your BIOS Setup. Youll notice the password is gone. If this fails try typing At command prompt type debug you will get a - prompt where you can type the following (<enter> means press enter, not type enter*) A <ENTER> MOV AX,0 <ENTER> MOV AX,CX <ENTER> OUT 70,AL <ENTER> MOV AX,0 <ENTER> OUT 71,AL <ENTER> INC CX <ENTER> CMP CX,100 <ENTER> JB 103 <ENTER> INT 20 <ENTER> <ENTER> just hit enter on this line G <ENTER> Q <ENTER> Basic BIOS password - works 9.9 times out of ten If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
2/18/2013 5:44:01 AM • ASUS K52F-BBR5... • Answered on Feb 18, 2013
Stuck during boot
Cheak your h.d.d or keyboard.try to open computer without hdd or k/b.
1/23/2013 7:43:47 AM • ASUS K52F-BBR5... • Answered on Jan 23, 2013
Monitor don;y work,i even hard it plug in the another moniter with a cable and still nother
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive including electrical extensions SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard or you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty if you cant get an exended desktop your graphics card might be dirty of faultyHope this helps.
1/19/2013 3:33:49 PM • ASUS K52F-BBR5... • Answered on Jan 19, 2013
Black screen at boot
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/28/2012 6:23:56 AM • ASUS K52F-BBR5... • Answered on Nov 28, 2012
TCL k42 laptop first screen admin password
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
10/6/2012 1:46:54 AM • ASUS K52F-BBR5... • Answered on Oct 06, 2012
Cover hinge broken model k52f
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site. http://www.insidemylaptop.com/replace-br... Acer parts are available from this WEB site. http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2839
9/2/2012 8:05:23 AM • ASUS K52F-BBR5... • Answered on Sep 02, 2012
Asus k52f forgot owner password
Go to the link below and download Ophcrack and burn the iso to a cd. Boot from the CD and let it do it's magic. You'll have the password shorthly:http://ophcrack.sourceforge.net/download.php
8/31/2012 5:27:44 AM • ASUS K52F-BBR5... • Answered on Aug 31, 2012
Where/how can I obtain windows 7 installation replacement disks? My hard drive/ hidden partition are both corrupted and I don't have back-up discs. Please help!!!
Go to www.asus.com contact customer support and the technical department, also! try www.ebay.com type make and model of laptop and scroll through the list.
6/23/2012 5:19:17 PM • ASUS K52F-BBR5... • Answered on Jun 23, 2012
Laptop will not wake up from hibernation
ok try thisturn off computerpress power button with battery and adapter removed for 2 min should clear the power settingsplug in adapter only(no battery)turn on computer see if it's happierif so, then install battery and restart
5/23/2012 6:34:29 AM • ASUS K52F-BBR5... • Answered on May 23, 2012
I want vga driver run to my web cem.plz tell me how
The Drivers for the Video (VGA) and the driver for the Webcam are two different things. If you screen works on other programs and displays things, then there is no need to download and install the Video Driver. If the camera is not showing, thats another issue.Get onlineand got to www.google.com In the google search box type: "ASUSSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Video drivers.I think you just have a Webcam issue so try the steps below.You have to open the webcam software to activate or startthe webcam. There is no button to push or switch to turn on. Thewebcam software is somewhere in the program list. Click Start/Programs thensearch for any reference to webcam or camera. Sometimes the webcam mightbe inside one of the manufacturers folders in the program list so search thefolders for it. Some manufacturers have something like EntertainmentExperience that will open and show all the entertainment devices such as thedvd drive, webcam, media player, etc. if you see it click it to launch itthen click on the webcam or camera icon. Try using ManyCamYoucan always download Manycam and install it. Go to www.google.com and inthe search box type: "download.cnet.com" (without the quotes). Click on the link to go to the site. When the site opens look down on theleft and you will see a gray area that says Find Software. Type"Manycam" (without the quotes) in the white search area then hit thesearch mirror. When it brings back your results look for the one thatsays ManyCam Virtual Webcam. Down load it and install it. Make sureyou remove the check box on any junky programs it would like to install. Youonly want to install ManyCam, no additions whatsoever during the install. ManyCam is totally FREE and easy to use, and you will always know where yourwebcam software is.
5/6/2012 2:03:53 PM • ASUS K52F-BBR5... • Answered on May 06, 2012
My webcam.my keyboard doesn't work
Hi
i know you said keyboard not working but please just try this
start up and straight away tap the F8 key to try to get into repair option
if you can try to do a system restore back to when it was ok
because some are saying that a recent windows update caused their hotkeys to stop working
or try the last known good configuration option
if you cannot get any keys at all to work please try another laptop or computer
and go online to
http://support.asus.com/download/options.aspx?SLanguage=en
and try to download some hotkey software or drivers
good luck
8/19/2011 11:58:55 PM • ASUS K52F-BBR5... • Answered on Aug 19, 2011
ASUS K52F-BBR5 Notebook Logo
48 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
K ASUS
  • K ASUS
Most Popular Question
bios password unlock
  • Computers & Internet
