20 Most Recent
Dell 2150cn / 2150cdn / 2155cn / 2155cdn Color Laser Printers Questions & Answers
MCU Firmware Error: Error 006-370: Code 00000001h on 2155cn dell printer
- Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
- Open an IP socket connection to that IP address.
- Write an HTTP data stream through that socket.
- Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
- for more help visit CBR Tech Solutions
Dell 2155cdn toner rubs off
It sounds like the fuser is not heating up to the correct temperature. If you are printing on specific papers, for example: envelopes, bond, linen, make sure to set your printer settings accordingly. Otherwise you will need a new fuser unit for the printer.
How to print black only, yellow is out?
Most printers will not allow you to print without all cartridges active. If you printer is capable of that you can go into the printer settings on the control panel and go into options or print menu. Under that you can select B/W printing only. Try that out.
Dell 1350cnw printer paper jam
Not sure if this will help, but I resolved mine in the end by opening the toner compartment and removing all of them then popping them back in. I also 'scrubbed' some sensors via a blue pullout bar in the toner area.When I started up the printer, I then held down the Red X button until it said 'ready to print'. It's working fine now.HTH,Tony
Paper jam error 234.01
paper jam 234.01 lexmark x364 dn
am not able to see the jammed papers how to remove them
urgent
Is a Dell V313 Printer WiFi capable?
all printers made , modern this is and was an option new
313 was an option, 2009 old printer it is,
the manual tells how to use that, here if it is present.
did you used USB before not told. and if yes or the seller did
used and you bought printer the printer must be reset;.
page 21
https://www.manualslib.com/manual/227801/Dell-V313.html?page=21&term=reset&selected=1#manual
or is this a pre buy question, if yes ask them.
can can not ESP THEM NOR PRINTER OPTIONS EVER.
non deities we are
page 55 is wireless setups.
The printer supports three wireless security options: no security, WEP, and WPA/WPA2
wpa2 is the best, others are super un-secure.
page 88
wifi trouble shooting is there.
if printer is used, (bought) page 89 must be reset
