20 Most Recent
Toshiba MV19N2 19 in. TV/VCR Combo Questions & Answers
No picture
If the unit powers at all and you hear some thing from the VCR, and then the unit powers off--problem is in the VCR.If total dead a fuse is of course possible--If none of these then the TV has a problem in either the High Voltage circuit or the power supply.To repair or to replace?
Is there a reset button
Not to discourage you from repairing this TV. In almost all cases, these TV combos are extremely difficult to repair. Even when these were new, if they had problems you will not get a long lasting repair.I would suggest you find another TV. Please refrain from purchasing any combo sets. Your best bet is to purchase a TV and DVD or VCR player as separate units. Thanks for asking and show all hands of support!
Remote won't work
you can build a ir sensore box find parts at radioshack or you could open your remote clean contacs with mild soap and water nothing else and do not use any thing that may scratch then check to see if your (leds) light emiting diodes are broken of the pc board
Digital TV Converter Box
I have a Panasonic TV with built-in VCR, I had Comcast put in a converter box and was given instructions on how to set up the system to record my wife's programs, I had to select the program (in advance of scheduled time) to be recorded through the TV & converter box to the VCR. Next styep- select "Show" and I received a menu the first of which was "R" I clicked the "R" and a menu for selecting Repeat record start/stop times appeared Click OK and was then directed to to set up the VCR according to Panasonic VCR instructions. Worked for a day then the "R" menu on the converter box disappeared. Both the VCR and TV had to be set to Ch 3 to get it to work, But that's history. When it quit working ("R" menu), I had Comcast come get their box . PS The tech who showed up to pick up the converter box knew nothing about any "R" (record) menus except on the most ecpensive converter box. That cinched my decision, Oh Wel!. Sign me Tom with less trash to watch.
Black square covers the center of the screen-
the closed caption is probably on. look on your remote or in the tv menu for cctv and change the setting. there are at least four different types of cctv and you may have to cycle around some to find "off.
Toshiba TV?VCR combo problem
you have bad caps in the vertical curcuit if you open it up you will see a smallmetal square ground sheild in there you will find two red caps look at them very carefully one will be wet it is leaking replac it
Menu
Yes most sets you can go into menu and reprogram in cable or ant. Does the set has a menu button? If not, does the remote have one?
Change batteries on my toshiba se-r0001 remote
- Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
- Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
- Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
- Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
- Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
- Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
- Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
- Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM •
Toshiba...
Answered
on Mar 09, 2024
