20 Most Recent Sony VPL-CX6 Multimedia Projector Questions & Answers
0answers
0answers
0answers
Sony vpl cx6
Be the first to answer 11/13/2012 5:50:46 PM • Sony VPL-CX6... • Posted on Nov 13, 2012Be the first to answer
0answers
I replaced the lamp in
check manual or call Sony
lots of optics on projectors have a coating on them that will be ruined if you use any type of cleaners on them
to be safe you could just try to blow dust off or wipe gently with a lens cleaning cloth
good luck!!
4/15/2011 6:15:51 PM • Sony VPL-CX6... • Answered on Apr 15, 2011
Power come on but dont
How old is the lamp? If the lamp fails that will give similar simptoms.
10/25/2010 9:02:28 PM • Sony VPL-CX6... • Answered on Oct 25, 2010
My laptop does not recognize vpl-cx6.
PLEASE FIND THERE TRACKING NO. ON THERE RECOGNIZED WEBSITE
6/5/2010 2:19:18 AM • Sony VPL-CX6... • Answered on Jun 05, 2010
Same here
if the fuses are ok and there is no st by light,
replace ic3100 in the psu order no.A-1302-316-A
1/12/2010 9:09:04 AM • Sony VPL-CX6... • Answered on Jan 12, 2010
My sony vpl-cx6 projector does not power up
If the fuses are ok, and there is no st by light,
1/12/2010 9:07:51 AM • Sony VPL-CX6... • Answered on Jan 12, 2010
2answers
VPL-CX6 PROBLEM
If the fuses are ok and there is no st by light,
replace ic 3100 in the psu, order no. A-1302-316-A
1/12/2010 9:06:12 AM • Sony VPL-CX6... • Answered on Jan 12, 2010
I have a VPL-CX6 projector
replace ic 3100 in the psu order no. A-1302-316-A
1/12/2010 8:52:30 AM • Sony VPL-CX6... • Answered on Jan 12, 2010
Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
8/4/2009 1:06:13 PM • Sony VPL-CX6... • Answered on Aug 04, 2009
Sony VPL-CX6 lens protector not opening
Your lap its not working , mabe is over 2000 hours , you need a new one.
6/30/2009 9:38:23 PM • Sony VPL-CX6... • Answered on Jun 30, 2009
2answers
Red color not showing in
Have you tried using the video inputs, Is it able to show red then ?
If not & you have reset the factory settings the prisim or mirror's may have gotten out of alignment in shipping, Or it may have a bad lcd panel or the red lcd may have a bad connection or driver circuit.
6/24/2009 1:18:53 PM • Sony VPL-CX6... • Answered on Jun 24, 2009
2answers
Hi i ve connect a
Hello. It seems that you have extended the desktop, when you only wanted it to display what was currently displayed on your laptop screen it self. You have two options from windows.
Method 1
You can leave everything set up, and simply click on the title bar, blue portion of open windows, and drag them across the screen as if you were dragging something physically from one side of the screen to the other, the window will continue past the right edge (by default) of the screen and onto your other screen, in this case, the projector. You can open the display properties, Right click desktop > Properties > Settings: and move the white boxes around to make you more comfortable if you would rather drag a window to the left instead of the right, just left-click and drag the 2 box to the left of 1.
That would allow for the least headaches given it is already working for you.
Method 2:
However, there is another option to try, which would be to select Monitor 2 as your primary display. in the same location as eariler, left click on Montior 2 and notice the two check boxes on the middle right. When "Extend my Windows desktop to this monitor" is checked you have an additional option "Use this device as my primary monitor. when you click this depending on which advanced options your manufacture has available, one of two things will happen.
Your projector will now show your desktop when your icons as if it were your laptop screen, and your laptop screen will show a blank desktop area in which you could drag windows over to as mentioned before
OR
Both the laptop screen AND the projector will display the same image.
It is my humble suggestion that you become comfortable left-clicking the title bar of windows and dragging them across the screen, to reduce the amount of hassles in getting method two fine tuned.
Remember that a window can not be dragged if it is Maximized, that is it takes up the entire screen. You must first click the restore button (The button resembling two squares ontop of one another between the Minimize "_" button and the Close "X" button) and then you can freely click and drag windows.
Rember also that the direction in which to drag windows depends on what you see in the Display Properties Settings Tab. Those two white boxes with numbers indicate physical placement of the monitors or "displays" If you are looking at your laptop, with the back of your projector parrallel to your laptop, facing you and it is on the left side of the laptop, you can not drag a window to the left of your laptop screen and have it go to the projector unless you have your monitor positions set up that way in the Settings. For that example, due to the left positon of the laptop, and making it more subconciously simple to use, you would need to left-click and drag box 2 to the left of box one.
Remember that right is default. So you dont have to change anything as long as you remember regardless of where the projector is physically in relation to the laptop, drag your window off the screen to the right.
Also, make sure to take care of the resolution settings for your projector in that box as well, once your comfortable moving windows around, left-click box 2 and adjust the slider for optimal quality.
Let us know if you need anything else.
4/17/2009 10:48:44 PM • Sony VPL-CX6... • Answered on Apr 17, 2009
4answers
Hi i bought sony VPL-CS1
From your laptops keyboard, try to press Fn first and F7( some laptop uses F6 for media options) key to set your viewing of your choice.
If not resolve, kindly give me the brand name of your laptop...hope this helps to resolve the problem
4/16/2009 12:08:43 PM • Sony VPL-CX6... • Answered on Apr 16, 2009
2answers
Green spot and message replace the lamp. New lamp gives same message
Have you gone through the menu, should be on the system tab, and reset the bulb reminder?
1/28/2008 8:09:32 PM • Sony VPL-CX6... • Answered on Jan 28, 2008
Sony VPL-DX220 3LCD Projector. How to unlock it please?
Question edited for a lot more clarity. Great Question. Press Menu Button for 10 seconds.
Data Projector
Projector Central https://www.projectorcentral.com > pdf > projecto... PDF Normal: Displays the image on the center position of the projected image without changing the resolution of the input signal or enlarging the image. VPL-DX270/ ... 54 pages
How to unlock control keys on sony projector? - Fixya
Fixya https://www.fixya.com > ... > Sony Sep 13, 2018 - To unlock the main panel keys, press the MENU button for 10 seconds. Read full answer. Aug 05, 2011 • Sony VPL-CS7 Multimedia Projector.
VPL-DX220
pro.sony https://pro.sony > ue_US > pdf > vpl-dx220 PDF Efficient, easy-to-use projector for classrooms and meeting rooms: with excellent picture quality and low ownership costs. The VPL-DX220 XGA projector is a ...
Sony VPL-DX220 3LCD Projector Specs
Projector Central https://www.projectorcentral.com > Sony-VPL-DX220 Sony VPL-DX220 Projector ; MSRP: $740 (USD) ; Resolution; 1024x768 ; Aspect Ratio; 4:3 (XGA) ; Contrast; 3,000:1 (full on/off) ; Color Processing; 8-bit. ‎Highlights · ‎Specifications · ‎Compare to Competition
3/5/2024 11:00:19 PM • Sony Office... • Answered on Mar 05, 2024
2answers
Sony vpl-es 5
How to unlock
Without remot
1/14/2024 6:05:02 AM • Sony Office... • Answered on Jan 14, 2024
Sony VPL-CX6 Multimedia Projector Logo
23 questions posted
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
replaced lamp in
  • Office Equipment & Supplies
