20 Most Recent
Sony Cineza VPL HS2 Multimedia Projector Questions & Answers
I have a Sony vpl-1 projector that on initial
If the projector has a lens cap, you have to help the projector to open it completely. Just use your finger and push the cap all ther way. On the projector I have this vis the case. there is a micro switch at the end og the lens cap opening mechanism.
[email protected]
LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't
when the bulb dies, but when a bulb has lost 10% of its brightness - so
you might well be able to reset the timer and get much more use from
the bulb - the image just wont be as bright.
I replaces my bulb in the sony vpl-hs10 and it
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Blue Haze from Sony Projector
Hello. Since the projector has had a bit of use, the convergance board capacitors are most likely wearing out and will have to be replaced.
Blue "Haze" at top of screen
My VPL-HS51 just started doing the same thing. There's a lot of similar reports out there and they all end up at the same bottom line - the problem is due to a design defect in the 'prism block' (LCD panel) and the only option, other than to throw it away or sell it for parts, is to pay Sony about $2300.00 to fix it. Good luck!
Lamp/cover button blinking red, how can I solve my Sony projector?
The blinking red lamp/cover button on your Sony projector typically indicates an issue with the lamp or the projector's internal temperature. Here are a few steps you can take to try to resolve the issue:
- Check the lamp cover: Make sure that the lamp cover is properly closed and secured. If the cover is not properly closed, the projector may not turn on or may turn off after a short time.
- Check the lamp: If the lamp cover is properly closed, the next step is to check the lamp itself. Remove the lamp and check it for any visible signs of damage, such as cracks or discoloration. If the lamp appears to be in good condition, try reseating it to ensure it is properly installed. If you have access to a replacement lamp, try installing it to see if the problem is resolved.
- Check the projector's air vents: Ensure that the projector's air vents are not blocked or obstructed, as this can cause the projector to overheat and shut down. Make sure that the projector is placed in a well-ventilated area.
- Reset the projector: Try resetting the projector by turning it off and unplugging it from the power source for several minutes. Then, plug it back in and try turning it on again.
- Consult the user manual: If none of the above steps solve the issue, consult the user manual for your Sony projector for further troubleshooting steps or contact Sony's customer support for further assistance.
If the issue persists, it may indicate a more serious internal problem with the projector that may require professional repair.
