20 Most Recent
Sony VPL-ES2 Multimedia Projector Questions & Answers
Sony svga vpl-es2 won't work
Its because for the foot there is switch who give signal to micro processor or system control.Fix it that.Your problem will solve.
My sony vpl-es2 displays the
Your bulb is going out. replace the bulb and you should be fine.
Just remember to set back to defualt settings before your change the bulb out and make sure your give the bulb time to pre-heat before you turn the project all the way on.
Can't reset lamp timer for
when you replace old lamp with new one the lamp timer not reset
automatically the counter is a
software data and you reset
manually with remote control
HOW :Connect the power cord to the projector. The ON/STANDBY indicator light in red
Use remote control and press the following key on the remote control in following order for less than five second each.
RESET +LEFT ARROW KEY+ RIGHT ARROW KEY+ENTER (as show in picture)
I have a Sony VPL
May be you have couple of weeks time to replace lamp in projector and don't forget to reset lamp timer hours as procedure would be mentioned in user manual.
I have a sony svga
Welcome to FixYa
Your Product Guide is
here
- Lamp/Cover Lights up or Flashes under Following
Circumstances
- When Lamp has Reached the End of its Life or
Becomes a High Temperature
- When the Lamp Cover or Air Filter Cover is not
Secured firmly
Temp/Fan lights up or Flashes under Following
- When Temp inside Projector becomes Usually High
- When Fan is Broken
For More Check Page
43 in
Guide[This may take few Minutes to Load].
In this guide can Solve any Problem about your Projector...
Also check this
Link...
Wide tips for Projector Click
hereHope you got an Idea....Thanks for Contacting FixYa...
Sony-ES2 Problem:
power supply problem. can't get enough power to keep it running. replace the power supply.
Sony VPL - ES2 Colour problem
Isolate problem by using video and data(PC),if none of the imputs work call the vendor or Sony and sent it back for repair.
