20 Most Recent
Toshiba SD-43HTS System Questions & Answers
Only plays background noise
check your sound mode key on the remote and press repeatedly till you hope fully get it back.......also be sure the center (voice channel) spkr wire is connected properly.....hope this helps!
"Protection Error"
the DVD is blocked in PAL system, ¿ How I can the DVD in NTSC system ? the menu is blocked. thank
Protection Error when switching on SD-43HK
You will need to get a service manual and trouble shoot what amp. circuit is defective. if you have no solid state printed circuit board experience, you really should take this unit in to a repair shop and have it estimated. There is no quick fix for this unit. Good Luck.
Toshiba SD-43HK Discs failing to load.
Sorry not a solution but experienced the same problem. The problem started off the same as you described by now my player won't play DVDs at all. Seems that the laser is faulty and it is cost prohibitive to repair (it's sold as a complete module which would be around £100). I've been advised to replace it :-(
Toshiba 32LV67U audio receiver code.
:It is possible that your TV is not compatible with the Xbox, or that you may need to enter a specific code. I suggest checking the manual for your TV to try and find the audio receiver code, as well as searching online to see if there are any additional instructions on how to connect it to the Xbox. Additionally, you may want to contact the manufacturer of your TV or Microsoft for further assistance.
I have a Toshiba Laptop
Most laptops do have Microphones built in. I do not know for definate that your laptop does, but you can easily test it to find out.
1. Go to the volume control (double click the speaker icon near the clock on the taskbar), go to recording properties and select microphone as the recording source and set the slider to about 80%.
2. Bring up microsoft sound recorder (its in the start menu somewhere) and click record... when you speak you should see a voice print appear in the sound recorder window.
If you do not see a voiceprint, then you probably dont have a built in microphone, but if you do see a voiceprint as you speak then you do have a microphone built in and you can record into your powerpoint shows to your hearts content.
Hope this helps!
