20 Most Recent
Toshiba (P000257700) Microphone Questions & Answers
Where is the built-in microphone.No one can hear
Microphone should be located on the lid of laptop above the screen by the latch release button. You will see a small rectangular hole (if you have a built-in webcam it is to the left of it)
5/26/2013 10:07:16 PM •
Toshiba...
Answered
on May 26, 2013
I got microphone on my laptop toshiba satellite L555D but its not woriking
sounds dumb but i have a toshiba sign up with scype the video msg. system dont buy any credits or anything takes like 5 mins and on the screen at the end it will do a sound check with a levels meter if its working youl see it move with sound. Also check the sound levels in computer settings its in there like 3 diffrent places the level is probl. turned down.
9/27/2012 6:10:36 PM •
Toshiba...
Answered
on Sep 27, 2012
No mic output
Possible fault in the connector or the shielded wire, fault in the cord.
IF the continuity is good , tested with a multimeter then the microphone switch and finally the coil continuity must be checked. If coil is open you will need help.
4/24/2012 2:40:45 PM •
Toshiba...
Answered
on Apr 24, 2012
I keep getting feedback from
This is quite normal. You have to avoid getting the sound from the speakers to the microphone. Either keep the volume lower or change the direction (mic - speakers).
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
9/16/2011 6:57:29 PM •
Toshiba...
Answered
on Sep 16, 2011
