20 Most Recent
Sony XL-2000U Projector Lamp for XBR800 serie Questions & Answers
I have sony tv sets
Obviously you should purchase the new bulb. (here: http://tinyurl.com/3chwjes )
1. unscrew the four Phillips head screws from the front (as you see the bulb)
2. slide the front out.
3. unscrew the Phillips head screw connecting the circuit
4. with pliers take off the nut attaching the other circuit
5. remove the wire holder
6. remove both golden fasteners.
READY FOR NEW BULB.
it is recommended to use a glove while touching the new bulb.
7. go backwards trough the steps until assembled!
Television
You probably just need a new lamp. If your tv is that old, im sure you do. I just got a new one from Projector Lamp Services (relampit.com) it works great... Only took me a few mins to install it too. I missed my TV!!!
Lamp bulb
Hi shanoo
I've learnt that most Projector brands can take Osram lamps - try finding a Osram agent near you and remember to keep the wattage of the lamp the same as the previous.
Need a replacement lamp for LCT50HV-tv syntax
Not looking good for your problem. I have not been able to find a supplier on the web or ebay. You might have to call the company and order it from them, but I bet it won't be cheap.
here is there contact page:
http://www.syntaxbrillian.com/company/locations.html
Product Support
Olevia Product Support
Call Toll Free: 1.866.9OLEVIA
or 1.866.965.3842
If this TV is less than 1 year old, you should still have the manufacturer warranty.
You should read the customer review at amazon:
http://tinyurl.com/34owj9
Reset the time on the lamp
Hi steelerector
While the Projector is in standby mode - in other words just plug in the powercord.
Hold down on the Projector's remote the left & right scroll buttons and press enter.
This will reset the Projector's lamp timer.
Sony kf60xbr800 lamp
Hi steelerector
It is really easy to do , you will normally get a little manual on how to do this with the replacement lamp.
Provided that the lamp is a original Sony lamp.
If not , then just unscrew the lamp door at the bottom , take out the two screws that fastens the lamp to the Projector's inside , replace the lamp and screw it back in and then put back the lamp door.
Then just remember to reset the lamp timer.
Replacement lamp
The lamp you received is correct. I own a lamp replacement company. It may of been pakaged incorrectly or maybe you received just the bulb and not the housing or vice versa (housing included). First, unless housing is damaged NEVER buy a new one...just the bulb will do. Housings are the biggest markup on replacement lamps. They are manufactired at a low cost and usually retailers drive up the lamp price because they include an uneeded housing. The bulb itself (XL-2100U) should be a round bulb. Check out my listing and compare this to what you received:
http://rearprojectionlamps.com/2000u-lamp-p-2277.html
Lamp/cover button blinking red, how can I solve my Sony projector?
The blinking red lamp/cover button on your Sony projector typically indicates an issue with the lamp or the projector's internal temperature. Here are a few steps you can take to try to resolve the issue:
- Check the lamp cover: Make sure that the lamp cover is properly closed and secured. If the cover is not properly closed, the projector may not turn on or may turn off after a short time.
- Check the lamp: If the lamp cover is properly closed, the next step is to check the lamp itself. Remove the lamp and check it for any visible signs of damage, such as cracks or discoloration. If the lamp appears to be in good condition, try reseating it to ensure it is properly installed. If you have access to a replacement lamp, try installing it to see if the problem is resolved.
- Check the projector's air vents: Ensure that the projector's air vents are not blocked or obstructed, as this can cause the projector to overheat and shut down. Make sure that the projector is placed in a well-ventilated area.
- Reset the projector: Try resetting the projector by turning it off and unplugging it from the power source for several minutes. Then, plug it back in and try turning it on again.
- Consult the user manual: If none of the above steps solve the issue, consult the user manual for your Sony projector for further troubleshooting steps or contact Sony's customer support for further assistance.
If the issue persists, it may indicate a more serious internal problem with the projector that may require professional repair.
Sony projector vpl-ex145 light ok, but no lable information
If your Sony projector (model VPL-EX145) has a light that is functioning properly but is not displaying any label information, there could be a few different issues causing the problem. Here are a few things you can try to troubleshoot the issue:
- Check the projector's connections: Make sure the projector is properly connected to the computer or device that is sending the video signal, and that the connections are secure. If the projector is not properly connected or the connections are loose, it can cause the projector to display a blank screen.
- Check the projector's settings: Make sure the projector's settings are properly configured for the type of video signal you are using. If the settings are not correctly configured, it can cause the projector to display a blank screen.
- Check the source device: Make sure the device that is sending the video signal (such as a computer or DVD player) is functioning properly and that it is properly configured. If the device is not functioning properly or is not properly configured, it can cause the projector to display a blank screen.
- Check for any other visible issues: Inspect the projector and its components for any visible issues that may be causing the problem. This can include debris or foreign objects that may have gotten stuck in the projector, or damage to the projector or its components.
If you have tried these troubleshooting steps and the problem persists, it may be necessary to have the projector serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
Touch screen not working for sony snaplab up-CR20l
Please turn off your device, clean the screen and power on the device before using it again. Otherwise, you might verify that you're using the device in an environment of moderate temperature. If still not working, then you might need to run a factory reset on the device.
Thank you.
