20 Most Recent Sony ICD-B7 Digital Voice Recorder Questions & Answers
Hello you can erase the recorded messages one by one or all massages in folder at time
Note once a recording has been erased, you cannot retrieve it.
Erasing messages one by one
1 Press ERASE while playing back the massage you want to erase or press ERASE for more than 1 second during stop mode.
A beep will sound and the message number and "ERASE" will flash while the first and last 5 seconds of message is played back 10 times
2 Press ERASE while the message is being played back.
The message is erase and the remaining messages will be renumbered. (For example, if you erase Message 3. When erasing is completed, the unit will stop at beginning of the following message.)
Erasing all messages in a folder
1 Press FOLDER to select the folder you want to erase.
2 While pressing STOP, press ERASE for more than 1 second.
"ALL ERASE" will flash for 10 seconds
While the display is flashing, press ERASE.
Sony ICD-B7... | Answered on Jan 29, 2014
i wisch one manuel french recoeder ICD-B7
Sony ICD-B7... | Answered on Jan 03, 2013
http://www.docs.sony.com/release/ICDB7.pdf
Sony ICD-B7... | Answered on Feb 22, 2011
Put it on hold. Slide the "Hold" switch up and leave it up. It does work.
Sliding the switch back down takes it off hold and turns it back on.
When off (hold switch on) pressing buttons will display a message that says "HOLD"
That alerts you that it's OFF and not dead.
Sony ICD-B7... | Answered on Nov 20, 2010
Look on the case. You'll see a button that slides. It takes it off of HOLD. HOLD mode is good to protect the recordings while the unit gets put in a pocket or purse.
Sony ICD-B7... | Answered on Sep 17, 2010
It does turn off necessarily unless you take the batteries out. You'll need to set the date again but it will retain the recordings it had.
Make sure you press erase twice and wait a few seconds for all of the files to pack. The unit fills the holes when a file goes away. You can erase say file 3, then it will pack all the files to put #4 in 3's old place, 5 in 4's old place and so on. Make sure you dont keep erasing the same number file becuase the new #3 file is the old #4.
http://www.docs.sony.com/release/filedownload.asp?Sub=&file=ICDB7.pdf
You need an audio cable with 1/8" connection on each end. Plug intot eh earphone jack on the B7 and then to your audio in of your computer. Use a sound recording program to record it. Its primitive but works fine. AUDACITY is a free program you can use.
It will turn OFF automatically after some time if non of buttons touched. (goes to standby mode)
It does not have any specific power off button.
Thanks.
Sony ICD-B7... | Answered on Dec 22, 2009
If this device is in warrenty, you may not do this. If you do diassemble this B500, then you lose your warrenty. I'm a technician in belgium, so I do know this things.
friendly greetings,
werner
Sony ICD-B7... | Answered on Jun 14, 2009
An adapter will not fix the problem. The files cannot be transferred to a computer using a USB port. The files must be transferred analog using the recorder's headphone cord. The files are then recorded to the computer from the Sony recorder using a program such as Windows Recorder. The ICD-B500 has many great features but archiving to a computer is not one of them.
Sony ICD-B7... | Answered on Nov 19, 2008
Call Our Customer Service and Support Call 1 8O5*465*751O Toll Free
24x7.............................
Sony Audio... | Answered on Jul 10, 2019
Sony ICD-B7 Digital Voice Recorder Logo
Popular Tags
19 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony icd b7 handheld digital voice
  • Audio Players & Recorders
