20 Most Recent Softheat Heating Pad HP218 12 3P Questions & Answers
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
8/16/2016 3:10:31 AM • Softheat Heating... • Answered on Aug 16, 2016
0answers
How can I disable auto shut off
Just note the chip number and Google it for the data sheet. when you found the actual data sheet read the pinout diagram of the chip to find out the Vcc pin. you have to cut the link of Vcc pin of the chip and the chip will stop working.
2/15/2014 6:11:07 AM • Softheat Heating... • Answered on Feb 15, 2014
0answers
0answers
I just bought a Fitbit Versa I tried to register using my email addresst was already registered to another fitbit. That was the fitbit I bought several years ago How do I register this fitbit?
Remove the old Fitbit from the account Fitbit app Tap Your data in Fitbit. Scroll down, and tap Delete Fitbit from your Google Account. Log in to your Google Account. Under Delete a Google service, tap Fitbit and follow the on-screen instructions.
How do I delete my Fitbit account and service? - Google Help
Google Help https://support.google.com > fitbit > answer
Remove old device for new one
Fitbit Community https://community.fitbit.com > Android-App > td-p Jan 19, 2021 - Hi @Bonnied07 sync and then remove the device from your account. click for directions. You'll want to move that old device out of range of ...
How do I remove Charge 2 from Fitbit account?
Fitbit Community https://community.fitbit.com > td-p About your old Charge 2, you can remove it by following these steps: Open the Fitbit app and tap your profile picture. Tap Charge 2 image: For iOS devices . ..
4/16/2024 5:28:05 AM • Health & Beauty • Answered Yesterday
Tan America VIP Gold 3200 Tanning Bed. I need a manual for vip 3200 ho tan America bed
Question edited for clarity 'make model (what it is). 'Manuel' is the name of a Spanish gentleman, a 'manual' is the book you want. It isn't leaping of the page at me. Try Tan Talk Forums as they have a section for Tan America Beds and also Sunal Parts who does spares and manuals. https://www.google.com/search?q=Tan+America+VIP+Gold+3200+owners+manual ..
4/14/2024 4:06:35 PM • Health & Beauty • Answered 3 days ago
Is intermittent fasting safe?
Yes it is generally accepted as perfectly safe and I know of a 50 year old and a 71 year old that does it. The 71 year old is a retired doctor. Intermittent fasting is safe for many people, but it's not for everyone. Skipping meals may not be the best way to manage your weight if you're 'with/child* or *feeding. If you have kidney stones, gastroesophageal reflux, diabetes or other medical problems, talk with your doctor before starting intermittent fasting.
Intermittent fasting: What are the benefits? - Mayo Clinic
Mayo Clinic https://www.mayoclinic.org > faq-20441303 https://www.google.com/search?q=Is+intermittent+fasting+safe ..
4/14/2024 11:50:24 AM • Health & Beauty • Answered 3 days ago
Beurer BF66 Weight Management Body Analysis Scale. How to reset my Beurer BF66 weight management scale please?
Question edited for clarity and toss in some CAPS. Deleted duplicate post. Refresh page to see your question. Remove the batteries overnight. Press and hold the Set Button for 2 minutes. Replace batteries. https://www.manualslib.com/manual/1084267/Beurer-Bf66.html?page=6#manual https://www.google.com/search?q=beurer+bf66+weight+management+scale+reset ..
4/14/2024 11:42:15 AM • Health & Beauty • Answered 3 days ago
Charger not working plug in light stays green, but battery is not charged
I have got 3 different chargers for my scooter. It's a Tifgalop T108. The charger light would stay green on the new chargers. My old one was the only one that was charging it. While I was replacing the charging ports, I came to find out that the negative wire is in a different location on the new ports. The negative wire was on number 3 on the old ones and is in number 2 on the new ones. After changing the ports all my new chargers work fine now.
4/14/2024 11:38:24 AM • Health & Beauty • Answered 3 days ago
Croc infrared flat iron for hair. It turns on then gives error message. What can I do?
Question edited for clarity, but it helps to know WHAT the error message or code is? Try a power reset first * to reset it: Plug your straightener in and hold the power button for about 20 seconds to reset it. Or contact them direct for Support, Warranty or Repair.
Frequently Asked Questions
CROC® Hair Professional https://crocofficial.com > pages > frequently-asked-questi... Most Croc flat irons can be used up to 240v. However, our older units did not have this feature, and we advise that you call our Customer Service Department ... ..
4/5/2024 12:53:16 AM • Health & Beauty • Answered on Apr 05, 2024
Boots skincare jill nowak
Hello there, "Boots" is a well-known pharmacy chain in the UK, and they have their own line of skincare products. However, "Jill Nowak" does not appear to be directly associated with Boots skincare.If you're looking for information about skincare products from Boots, you might want to explore their own-brand products or specific lines they carry. For personalized skincare advice or recommendations, consider consulting with a dermatologist or skincare specialist who can provide guidance tailored to your specific needs and concerns.
4/5/2024 12:03:08 AM • Health & Beauty • Answered on Apr 05, 2024
Softheat Heating Pad HP218 12 3P Logo
18 questions posted
Popular Products
Top Softheat Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Softheat Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Softheat Health & Beauty
Most Popular Question
mod hp980pt red top green light flash
  • Health & Beauty
