20 Most Recent
Paradyne (6211-A1-200) Router Questions & Answers
Admin password reset
Easy, hit the tiny reset button then restart. Alternately read the backup log file in notepad. it gives all the info you need unencrypted and in plain english.
3/21/2010 8:24:15 PM •
Paradyne...
Answered
on Mar 21, 2010
When connect main power paradyne ups offline fuse burnout.
Not exactly sure what you are saying.
When you turn on your UPS it blows the main fuse? Obviously you have a short. If you just changed the batteries I would go back and check that you have the positive and negative cables are connected correctly and there is nothing pinching the cables or touching the terminals.
If you didn't recently change the batteries and this might be a result of lightening, I would change the fuse and see what happens. If it continues to blow, toss it and get a new one. Could be the circuit board is bad but most likely the transformer is shorted. Unless you are a trained electronics technician you should not go any farther.
7/22/2016 4:40:03 PM •
Paradyne...
Answered
on Jul 22, 2016
Wifi signal is very weak
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default. Change to anotherchannel.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedropouts and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
6/30/2012 10:52:28 AM •
Paradyne...
Answered
on Jun 30, 2012
I have a paradyne 621x
Is this a DSL modem? and if you need drivers then are you trying to install this thru USB connection only?
8/9/2010 11:23:33 PM •
Paradyne...
Answered
on Aug 09, 2010
Default password not working
you have to reset the router by pushing in on the reset button with a pen. this resets the router security to just a user id, no password. ID should be admin.
11/11/2008 2:47:26 AM •
Paradyne...
Answered
on Nov 11, 2008
