20 Most Recent
Paradyne ADSL/R 6381 Router (6381-a2-200) Questions & Answers
Can not get my PCMICA Wireless Landcard to work
Old technology! The operating system is out of date and there are no drivers to support the computer and software any longer.
BrosTrend 1200Mbps USB WiFi Network Adapter; Dual Band AC 5GHz WIFI Speed 867Mbps, 2.4GHz 300Mbps; For Desktop, Laptop, PC of Windows 10, Windows 8, Windows 7 /Vista/XP; USB 3.0; AC 1200 (AC1 Model)
My company provided me wired
Since your D-Link 2640 is a modem + router it may not work the way you intend.
You need just a wireless router without modem.
Run a small Ethernet patch cable from your Paradyne modem into the WAN port on your router, you can plug your existing Ethernet cable into one of the other LAN ports on the router, then access the router setup using the computer connected to the Ethernet cable using a browser and putting the router's IP address into the address line of your browser. It will most likely be 192.168.0.1 or 192.168.1.1.
Once you have configured the Wi-Fi router you will have your wireless network. Full instructions should come with the router.
Routers are available for as little as $29.95 but expect to pay closer to $79.95 for satisfactory speed and capability.
The combined Paradyne router and
You buy a new one, you install it in the place of the other and you configure it following the manual - you will need the connection data from your ISP (username and password - they are in the contract).
If you no longer have it you can download it from here
http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
What is the ip address of paradyne 6381 a3 300
To configure your router, open your web browser. Type the default IP address (
http://192.168.1.1) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is 192.168.1.1
The default user name is Admin
The default password is Admin
Both are case-sensitive.
Adsl connection
The error Destination not reachable is due to a router not having a route in its routing table; to fix it I suggest consulting your documentation and/or using the admin console and its built-in help to add the route you need to its table. Note that 192.1.1.x is unreachable from 192.1.2.x LAN segment. Not familiar with Paradyne routing syntax, so I would try their web site if available for full details. If you can be more specific about the IP addresses (subnets, they're called) in question, I can provide more info. as to how its done.
Cannot access my modems home page.
Nore than likley that is the default LAN IP address that came with the device. It has probably been changed during the initial setup. A quick way to tell is go to your start button/ select run / type in the run box CMD / this brings up a dos shell in the dos window type IPCONFIG and hit enter.. Note your IP address and your default gateway.. " the default gateway is your device in question. make sure your IP address matches your gateay with the exception of the last 3 octects. so it should read something like this
IP Address 192.168.1.50
Subnet mask 255.255.255.0
Gateway 192.168.1.1
My guess is that your not on the "1" network but the router is handing out a different range of address if that is the case in the dos window type ping (the ip address of your default gateway)
like so ping 192.168.X.X where X = the octet values of the default gateway listed in the dos window
If it replies then your talking just fine you are simply trying to access your router via the wrong IP so take the IP of the gateway listed from the ipconfig command and put that number in your browser.
If this is not the case then we need to go in a different direction with this.
MilToN
CNA,CNE,MCSE,CCNA,Network +
