20 Most Recent
Aiwa CDC-X304 CD Player Questions & Answers
Buttons stopped working
sounds like you may have a bad switch. if you have a multimeter you can check to see if a switch is reading less then a few megaohms. if one is reading a few kilo ohms, it is probably bad.
CDC-X304 in permanent DEMO mode
I HAVE SAME PROBLEM. AFTER I REPLACED MY DEAD BATTERY MY AIWA CDC-X304 IS STUCK IN THE DEMO MODE. ONLY CD WORKS BUT ALL BUTTONS ON FACING DO NOT RESPOND. ANY SUGGESTIONS HOW TO RESET.
Can't get the player out
try taking the deck out of the car and unhooking it for a while that should reset it to factory settings
I have power to my
If the stereo does not power up at all:
Make sure the stereo is getting the 12VDC. Check if there is a fuse on the back of the stereo.
It may be also a fuse inside the stereo, it could be a short circuit due to a bad audio output ICs or bad control circuit.
If the stereo powers up but no sound: See if you can reset the stereo by disabling the power that is going to the stereo, perhaps by removing the radio Main fuse for a couple of minutes (this may clear all memory including stations and clock)
It may also be a bad audio circuit, Speaker wires or connectors.
Good luck
Sabre
