20 Most Recent 1999 E150 Questions & Answers
When i start my 1999 e-150 van sometimes it idles rough for 20 seconds then its ok.should i put some fuel cleaner in to clean the system?
You need to remove and clean the air bypass idle speed control valve and the throttle valve and bore, they get gunked up from combustion "blow back" and that causes stalls and rough cold running. Use only CRC Throttle Valve cleaner (any auto parts store) on both parts, carb spray will destroy the non stick coating inside the parts.
11/23/2016 7:47:50 PM • 1999 E150 • Answered on Nov 23, 2016
WHERE IS THE TURN SIG FLASHER FOR THE 1999 FORD E150 CONVERSION VAN
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem. Best Manuals
11/5/2016 6:02:03 AM • 1999 E150 • Answered on Nov 05, 2016
Why does it stumble when excellerating at slow speed?
has it had a service recently, spark plugs, air filter, etc. maybe idle control valve does the rev counter hunt when engine running?
1/13/2016 4:13:31 PM • 1999 E150 • Answered on Jan 13, 2016
2answers
My 1999 e150 van has a wobble on the passenger side also the tire on that same side when i give it some gas won't turn right away?
this has to checked by a garage , one dealing with steering/suspension /tyres. It is not a job that should be attempted by the home mechanic. It may be that the wheel mentioned has sustained some damage, or the wheel is severely out of balance but , whatever the case, it sounds as though your steering geometry is out of kilter anyway. This is a serious risk and should be sorted before you subject your vehicle to any great usage, it could be a hazard to yourself and others. Good Luck
12/7/2015 12:04:02 PM • 1999 E150 • Answered on Dec 07, 2015
2answers
I have a 1999 Ford E150 with a 4.2 and is getting codes p0401 and p0325. I need egr diagrams and electrical drawings for this van. Everything is new in the system and suspect it is electrical.
I hate to say it but you probably have to take it to a Ford store. They guard the info you need to find it. EGR is very complex and with all the digital busses in the vehicle moving data back and forth, the old broken wire etc fix isn't usually available any more.
10/5/2015 2:34:17 PM • 1999 E150 • Answered on Oct 05, 2015
Cannot find IAT sensor on my 99 ford E-150, 6 cyl.
what do you mean?
3/22/2015 7:17:26 AM • 1999 E150 • Answered on Mar 22, 2015
1999 ford e150 over heating?
Check you have enough coolant, power wash your radiator, check your radiator cap if the rubber seal os good
8/18/2014 7:24:48 AM • 1999 E150 • Answered on Aug 18, 2014
Ford e150 is leaking somewhere on driver side when it rains?
If it ain't the windows. It is probably an air vent seal. Does it leak only when it is being driven or also when it is parked? Check in front of the windshield - clean out the vents etc... check the gaskets going into the cabin around the wire harness inlets etc. If you can't find a hole - it might just be condensation from the air conditioner hose.
7/19/2014 4:20:04 PM • 1999 E150 • Answered on Jul 19, 2014
tip
Diesel Pump Rotor Head 1 468 334 337
diesel Pump Rotor Head 1 468 334 337 Item Name(EH)#injector bmw 320d e46# # head rotor ford 12 mm# #head rotor ford 187l# #injector chrysler voyager# #for injector common rail delphi# #Ultrasonic Injector Cleaning Machine #UltraSonic Fuel Injector Cleaning (EH)China Lutong Parts Plant is a famous manufacturer and supplier specializing in diesel engine parts.We have 30 years experience in this area. Our aim and business policy is to give the customer a reliable quality product and service, alternative to the OE products. The parts are quality assured to ISO9001 and are subject to regular internal and external audits ensuring that quality is the highest standard. nicole(at)china-lutong (dot) net Wha/tsa/pp:+86133/8690/1375 nicole(at)china-lutong (dot) net [email protected]
/uploads/images/7123-909t-head-rotor-for-perkins (3)-undefined-undefined-0.jpg
I have a 1996 ford windstar
They remote is for the immobiliser system. Immobilisers are designed to be VERY difficult to bypass otherwise why fit them? Your simplest solution here is to go to a car key specialist and get a new remote. Once the old one fails the car will not start at all.
7/5/2022 6:27:29 PM • Ford Vehicle... • Answered on Jul 05, 2022
Has anyone code for mondeo radio Serial no. V041312
M000281
8/28/2020 4:12:21 PM • Ford Vehicle... • Answered on Aug 28, 2020
3answers
I want to decode my Ford Feista radio ,SAM Model no 14790945. serial number 339486610945
Can anyone help me get the code for my ford focus 2005 model radio code sam model 222599250900 ?i would very much appreciated anyone could help me with this thanks in advance
12/11/2019 10:48:58 AM • Ford Vehicle... • Answered on Dec 11, 2019
2answers
Need radio code for ford bantum bakkie
Search for on google
3/19/2019 4:03:15 AM • Ford Vehicle... • Answered on Mar 19, 2019
Adjust transmission bands
Which transmission? Some bands are not adjustable without getting into the transmission case.
2/19/2019 7:40:29 PM • Ford Vehicle... • Answered on Feb 19, 2019
In Need of a Code to unlock my Radio Please.
A qualified service center can ask a dealership for the code or go directly to the dealer.
2/19/2019 7:39:12 PM • Ford Vehicle... • Answered on Feb 19, 2019
Just replace a Ford Falcon AU radio with a
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u .. U can also get free manuals
1/29/2019 8:27:39 AM • Ford Vehicle... • Answered on Jan 29, 2019
Install bulldog model RS112 into a 2005 Ford Taurus
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of all the times I fixed the chipper in these 4 years
1/25/2019 3:32:42 PM • Ford Vehicle... • Answered on Jan 25, 2019
Im having a problem with my remote start. It goes on , but shuts off in 15 seconds. I have a Ford Explorer with a viper alarm.
Just a guess, since some disengage if signal not getting thru that motor running, to prevent starter brushes overheating, burning, etc, and you say motor starts, maybe a dirty electrical connection, like oil or something got in somewhere, interfering with that signal being received. To rule that out I guess yourself or shop, have all electrical connectors looked at for oil, dirt, oxidation, loose, etc... Simply pulling connectors and pushing back on few times might do it if that the issue. Notice if it feels tight or not. If oily dirty, maybe spray male and female parts of connector with alcohol based spray degreaser. Silicone spray has fast evaporating alcohol but the silicone may interfere with electrical connection. Also, be sure your remote button not triggered by weak spring contacting when you set it down or put in pocket as that'll act to shut off if already on. I had 1 get like that. Would park car, head in, putting remote in pocket after going in, would notice car running from inside.
11/9/2018 2:05:23 AM • Ford Vehicle... • Answered on Nov 09, 2018
Water not curclating around engine
either a stuck closed thermasa or a waterpump
10/21/2018 12:19:46 PM • Ford Vehicle... • Answered on Oct 21, 2018
2008 yukon heat doesn't work in the front but comes on in the back
it could be a couple of things. it could be the main blend door actuator. the other could be a blower motor.
9/21/2017 4:28:58 AM • Ford Vehicle... • Answered on Sep 21, 2017
1999 E150 Logo
8 questions posted
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Ford Vehicle Parts & Accessories
Most Popular Question
1999 e150 van wobble passenger side also
  • Vehicle Parts & Accessories
