first look at the charging jak deeply posibel its water dameg or not you hay to cleen up with normal dental brush.and second opcion you have to chang your charger but buy orignal charger
I have used icloud too, and know what your working with this is always a tough one.
backup only backups automatically when your devise is connected to internet and is charging. It wouldnt mess with email and you should see how much space your backup takes to know if it exceeds youricloud storage uploadable amount
This is not specific for the iPhone. It has everything to do with your provider. He decides when a call is put to a voicemail or when it is stopped. But most of the time you can change the time yourself, but please check your mobile phone provider how to do so.
When you say you email stuff to your gmail account, what account are you using as the sender's account? There could be different reasons but the easiest way is to go to SETTINGS, MAILS, CONTACTS, CALENDARS, and reenter passwords for all the email accounts you have on your phone. That should do the magic.
No need to save the alarm. When you select "Alarm" in the Clock app ... you add and Alarm by touching the + sign, enter a time you want to Alarm to go off ... the first time the "slider" that turns the Alarm On/Off will be green - in the on position. When the Alarm goes off you turn if off by sliding the windows from left to right. The alarm will still be saved in your list of alarms ... when you want to add another Alarm, just touch the + sign again. If you want to activate a previously added Alarm, just slide the button to the right to On ... I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
Apple Inc.Nov 11, 2015 - And with AirPlay Mirroring, you can display your iOS screen on yourApple TV. ... For music: Apple TV, AirPort Express, or AirPlay-enabled speakers. ...iPhone 5 or later; iPad mini or iPad (4th generation or later); iPod touch ...
Some troubles appears along with Apple releasing iPhone 6 and iPhone 6 plus.
I can't play HD AVCHD movies on iPhone 6/6 Plus. This is kinda embarrassing.
But soon, I get a solution - Aunsoft Video Converter.
http://www.aunsoft.com/video-converter-mac/
You can resort to 3rd-party iOS data transfer tool - Leawo iTransfer to help you to transfer music from PC to the iPhone 5C. Just check below steps.
Step 1. Run Leawo iTransfer and connect iPhone 6s to computer with USB cable.
Step 2. Add music you like from computer to iPhone 6s.
Note:There are 5 ways to add files from computer:
A.Drag and drop the computer files directly into the window of the software;
B.Right-click music library and choose "Add File" or "Add Folder";
C.Click "File" on the upper right corner, and choose "Add > Add File/Add Folder";
D.Right-click music library and click "Add File";
E.Click "Add" button on the top left, then choose "Add File" or "Add Folder".
Step 3. After adding music to the software, it will automatically begin to transfer music from computer to iPhone without iTunes.
Of course, as a dual-way iPhone transfer tool, excepting for transferring music from computer to iPhone, Leawo iTransfer also allows users to transfer music from iPhone to computer for backup.
For more details, check: How to Transfer Music from Computer to iPhone
if its over two 1/2 year old its free to unlock from any carrier just ring the provider and ask for unlock code i do this all the time i have never had a new phone.
the digitzer broke and needs replaced go on ebay and buy a new digitizer and lcd comes altogether as one piece and change it , not to hard but easier to pay someone to do it for about 60 bucks
No. The i cloud account belongs to that owner forever. You should do a factory reset and create your own cloud account. Cloud accounts are where personal data is stored.
I suggest you can approach Mobile-unlocker.com and specify the country,locked network of iPhone 5C .Based on the availability you can get the permanent unlock service along with free instructions.
If you have a Mac, you can import certain formats from previous address books or, if you already use Contacts, simply sync it on iCloud.
On the phone itself, you can open the Contacts app or the Contacts button in the Phone app, and add each address, one-by-one, by touching the + icon in the upper right of the screen and completing the blank card. Once you touch "done", you can go on to the next. If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
if you use iOS 7 or 8, swipe up from the bottom to bring up the menu. ON the top row of icons, on the farthest right there is an icon with a lock surrounded by a circular line and arrow. Tap this to toggle the rotation lock on and off.
iOS An app you installed unexpectedly quits stops responding or wont open
iOS: An app you installed unexpectedly quits, stops responding, or won't open
Learn what to do if an app you downloaded from the App Store on your iPhone, iPad, or iPod touch unexpectedly quits, stops responding, or won't open.
Follow the steps below and test the app after each step.
Restart the app
Close the app and open it again.
Restart your device
Turn the device off and on.
Update your device software and your apps
Update your device to the latest version of iOS.
Update your apps:
Open the App Store and tap Updates.
If updates are available, tap Update All.
If asked, enter your Apple ID password. The updates will download and install.
You might need a Wi-Fi connection to update some apps.
Install another app from the App Store
If your installed app won't open, download and install a free app that isn't on your iOS device. This should reset your Apple ID authorization.
Remember to use the same Apple ID that you used to download the app that you're having issues with.
Reinstall the app
Remove the app from your device and reinstall it. Remember that deleting an app also deletes its data.
Wait for the app to download, then open it from the Home screen.
If the download stops, you can resume it.
Contact the developer
If you see the issue again, contact the developer of the app for help:
Find the app in the App Store.
Tap the app and tap Reviews.
Tap App Support.
Information about products not manufactured by Apple, or independent websites not controlled or tested by Apple, is provided without recommendation or endorsement. Apple assumes no responsibility with regard to the selection, performance, or use of third-party websites or products. Apple makes no representations regarding third-party website accuracy or reliability. Risks are inherent in the use of the Internet. Contact the vendor for additional information.
Last Modified: Nov 14, 2014
Apple Customer Phone Number Shortest Wait Best Support
Talk to a Human
Press 0, then press 5 OR For tech support, have serial number ready. Don't press zero -- say "iPhone Support" (or whatever product you're calling about). The system will ask you for serial number and get you right to someone who can help
I'd say go to the straight talk, Apple might be able to help but since it's not a contract it's probably better to go t straight talk.
im a iPhone 7 plus user.
