20 Most Recent Casio Desktop Calculator - DJ-220D Questions & Answers
Follow the instructions in the fourth column of the instruction sheet. If you need a copy, you may download it at http://support.casio.com/storage/en/manual/pdf/EN/004/DJ-120D_Plus_etc_WB_EN.pdf
Casio Desktop... | Answered on Sep 14, 2016
Whats the point of the % button then?
Casio Office... | Answered 2 days ago
you shud be able to find anything you need here>>>www.discountbargainprices.com
Casio Office... | Answered on Apr 16, 2019
the function buttons are labeled + and -
to add put in the number then press the + button then put in the next number and + and son for all the numbers you are adding up
to subtract put in a number then press the- button ,then put in the next number and press the - button and so on
to do a combination calculation put in a number then press the + button and so on until you come to a number that you want to subtract in which case you put in that number then press the - button and if the next number is to be added ,put the number in and press the + button
Casio Office... | Answered on Apr 15, 2019
Seems to be a common problem on this otherwise great calculator that helped me through both high school and university. I've had mine for nearly 20 years and this problem showed up a few years ago. But I remember classmates reported the same problem when it was almost new.
If replacing batteries isn't helping, the problem is most likely caused by oxidation on the springs connecting the battery holder to the main PCB. The solution is as follows:
1. Remove the metal back cover (2 screws)
2. Remove the plastic back lid by removing the black screws (leave the batteries mounted) and CAREFULLY slide the back lid to the lower end (where the EXE button is located). Do not lift while sliding until the lid easily comes off.
3. On the back side of the plastic lid, very carefully bend the the two metal connectors ~1 mm on both batteryholders to increase their tension.
4. Clean the connecting pads on the PCB and the metal springs with de-oxidizer solvent.
5. Re-assemble and your 4500P calculator should be good as new.
Casio Office... | Answered on Apr 02, 2019
Casio Desktop Calculator - DJ-220D Logo
7 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
change tax rate in dj 220d
  • Office Equipment & Supplies
