20 Most Recent Dualit Vario 3 Slices Toaster Questions & Answers
2answers
Our Dualit toaster doesn't work. The
You need to replace the timer-contactor. This part is acting both as timer and electrical contactor. It consist from electrical contact moved with springs on and off. Due to electrical load and extreme heat these contact have been tear out thus they can not contact properly and in your case they don't contact at all.
So from the web page of dualit or ebay you can order A new timer contactor and replace it.
6/5/2016 5:28:07 PM • Dualit Vario 3... • Answered on Jun 05, 2016
I have an old Dualit Vario 3 Slices toaster. It has not been serviced for many years and needs a thorough inspection. Is there anywhere in Adelaide, South Australia, where this can be done?
I haven't been in Adelaide since 1988. Until you find a place to service it, try this. Unplug the toaster, turn it upside down over the sink or a sheet of newspaper, shake it a little bit to get rid of crumbs. Do this about 3 times or until no more particles come out. It is best not to stick anything inside except slices of bread. Good on ya. I hope your weather is beautiful, we are at -11 degrees Celsius tonight here in Canada. P.S. I low the pink Galahs.
3/2/2015 1:35:25 PM • Dualit Vario 3... • Answered on Mar 02, 2015
2answers
Hi our 3 slice dualit toaster gets stuck when you
We have the same problem and it has been on all day, and credit to the toaster it has not yet burnt out an element, I am looking to replace the timer as I found that the pivot inside is on a plastic bearing and that has worn, I did find a timer on a web site but cant find it now.
10/29/2012 12:48:46 PM • Dualit Vario 3... • Answered on Oct 29, 2012
Combi 2 plus one, bought
I think the MI7 timer is equivalent. The best prices are on ebay. You can also check in with appliance repair shops. Electra-Craft lists Dualit timers, but again, I am not sure if these are what you need: http://www.mcssl.com/store/electra-craft/catalog/search?keyword=dualit+timer
1/29/2011 7:04:13 PM • Dualit Vario 3... • Answered on Jan 29, 2011
The dial gets stuck and the toaster does not shut
You need a new timer they are available on ebay but they are pricey
1/5/2011 1:41:03 PM • Dualit Vario 3... • Answered on Jan 05, 2011
Doesn't toast
ON SWITCH
4/10/2010 6:14:25 PM • Dualit Vario 3... • Answered on Apr 10, 2010
I need the elements replacing
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
4/2/2010 7:44:07 PM • Dualit Vario 3... • Answered on Apr 02, 2010
I think the elements are no longer working. can
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. They can not be fixed.
Good Luck
4/2/2010 7:39:01 PM • Dualit Vario 3... • Answered on Apr 02, 2010
Recently it has taken longer and longer for pieces
Good Luck
4/2/2010 7:34:07 PM • Dualit Vario 3... • Answered on Apr 02, 2010
Dualit toaster - timer sticking.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
4/2/2010 7:19:45 PM • Dualit Vario 3... • Answered on Apr 02, 2010
Are my elements broken?
no this is normal
11/1/2009 2:32:31 PM • Dualit Vario 3... • Answered on Nov 01, 2009
Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
11/30/2008 11:17:35 AM • Dualit Vario 3... • Answered on Nov 30, 2008
Wiring diagram needed for 3 slice dualit model auto 3
get it at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
11/20/2008 5:00:58 PM • Dualit Vario 3... • Answered on Nov 20, 2008
2answers
Eliment
Did the top element ever work? Perhaps it only works in "broil" setting.
hamar nnelg
11/20/2008 5:00:32 PM • Dualit Vario 3... • Answered on Nov 20, 2008
Dualit Combi model (made in UK)
service center in US:
Electra-Craft
41 Woodbine St
phone 201-439-1700 ask for Steve Karow
fax 201-439-1701
[email protected]
11/20/2008 4:59:43 PM • Dualit Vario 3... • Answered on Nov 20, 2008
Heating elements turn off while timer is still running
ask the service center at;
Electra-Craft
41 Woodbine St
phone 201-439-1700---Steve Karow
fax 201-439-1701
[email protected]
11/20/2008 4:58:22 PM • Dualit Vario 3... • Answered on Nov 20, 2008
Toaster: Dualit Domus DLT44... First one side now the other.. Dead!
Question edited for clarity, added full stops as Fixya removes formatting and line breaks. Question moved from Cars and Trucks to correct make category. The latching is normally dependent on the element working. If you have a multimeter, test continuity of the elements. replacing them is normally not easy as domestic toaster use crimped wires direct to the elements cassette. I have a brand new one in my garage for a Black and Decker toaster with 18 crimp wire tails. I used Dualit and Rowlett commercial toasters at my hotel in Cornwall, England, and they were easy to repair, but Domestic toasters are really a non repairable / replacement option. Ask Dualit what they think? https://www.dualit.com/support/domus-4-slot-toaster ..
8/11/2022 3:03:11 AM • Dualit Kitchen... • Answered on Aug 11, 2022
Dualit Vario 3 Slices Toaster Logo
Popular Tags
20 questions posted
Top Dualit Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dualit Kitchen Appliances - Others
Most Popular Question
our dualit toaster doesn 39 t work
  • Kitchen Appliances - Others
