20 Most Recent VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09) Questions & Answers
I need drivers for VGA graphics Adapter...DELL
Hello you can download the driver here:http://www.dell.com/support/drivers/us/en/19/Product/vostro-3300There are too different ones soo you have to try it.The files must be unzip before installation.Good luck
10/20/2012 2:11:24 AM • VIA ASRock K7VM3... • Answered on Oct 20, 2012
Sound is not coming
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets is usually at the back of the computer or if it
10/27/2011 11:26:24 PM • VIA ASRock K7VM3... • Answered on Oct 27, 2011
2answers
Sir,m looking for video driver
Hi :) Here is the site for the drivers and manual for that board you just have to download them.There are no driver for that operating system as of yet. But you should be able to use WindowsXP drivers.
http://www.asrock.com/MB/download.asp?Model=K7VM3&o=All
3/27/2011 5:12:43 AM • VIA ASRock K7VM3... • Answered on Mar 27, 2011
2answers
Sound problems after transfer into new box
http://download.asrock.com/manual/K7VM3.pdf
I hope this not the same manual.
5/8/2010 1:36:12 PM • VIA ASRock K7VM3... • Answered on May 08, 2010
2answers
Shut down after 5 - 10 min.
the most likely case is CPU-OVERHEAT EMERGENCY POWEROFF command executed by motherboard in this case apply new thermoaste on cpu, and clean fan/replace on bigger if doesn't help/cpu is overclocked
9/22/2009 1:15:41 PM • VIA ASRock K7VM3... • Answered on Sep 22, 2009
Computer shuts down after 10-15 minutes
it my be your ram
8/11/2009 2:18:02 AM • VIA ASRock K7VM3... • Answered on Aug 11, 2009
8233avg
What is your question?
8/6/2009 6:16:20 PM • VIA ASRock K7VM3... • Answered on Aug 06, 2009
2answers
I want VGA drivers for VIA chipset 8233
hiiii Please goto this site i.e. http://www.viaarena.com/default.aspx?PageID=2 and as per your selection of OS you can find you driver of your motherboard.
6/29/2009 4:33:06 PM • VIA ASRock K7VM3... • Answered on Jun 29, 2009
Driver motherboard asrock 1333 d667
You can download the reuired drivers here:
http://www.asrock.com/mb/download.asp?Model=ConRoe1333-D667%20R2.0
5/30/2009 7:34:50 AM • VIA ASRock K7VM3... • Answered on May 30, 2009
Asrock conroe 1333 d667 R1 driver
all the drivers for that motherboard are available from this link
http://www.asrock.com/mb/download.asp?Model=K7VM3
2/25/2009 3:22:23 AM • VIA ASRock K7VM3... • Answered on Feb 25, 2009
N?o comsigo baixar o driver de video
downlod audio n video driver
2/4/2009 10:48:23 AM • VIA ASRock K7VM3... • Answered on Feb 04, 2009
2answers
I need mainboard drivers
go to www.driverguide.com make a free account and download your required drivers for free...
best regards,
1/27/2009 10:34:49 AM • VIA ASRock K7VM3... • Answered on Jan 27, 2009
7answers
Graphics driver
VT8233/A AC'97 Enchanced Audio Controller
12/5/2008 9:31:10 AM • VIA ASRock K7VM3... • Answered on Dec 05, 2008
K7vm3 mobo RAM
If you are referring to the ASROCK mobo then it will work on the high density although not as good as with the low density but it will nontheless work.
10/13/2008 2:21:11 AM • VIA ASRock K7VM3... • Answered on Oct 13, 2008
K7VM3
An ASRock K7VM3.motherboard is a socket A (462) board specifically for the AMD processors. To my experience, these boards (due to age and period of usage) are prone to:
  • bulging/leaky capacitors of the high current regulators near the CPU;
  • the heatsink tends to be dislodged/misaligned causing overheated processor;
  • loose memory slots causing defective memories.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
10/2/2008 12:26:22 PM • VIA ASRock K7VM3... • Answered on Oct 02, 2008
Pc monitor problem
2w2qq2q2q
9/25/2008 1:10:20 PM • VIA ASRock K7VM3... • Answered on Sep 25, 2008
2answers
Bad graphic
Your motherboard only supports AGP. You can use any AGP graphics card that supports up to 4X AGP. nVidia and ATI make great cards as well as other manufacturers that mak boards using nVidia and ATI chipsets. I would recomend a card with at least 512MB of memory onboard. I hope this helps.
Lou
9/11/2008 1:58:00 PM • VIA ASRock K7VM3... • Answered on Sep 11, 2008
2answers
Video driver
Vista Black edition is a pirate copy of Vista, it is probably infected by some malware that will slow the entire system down in time, not just the video display
8/31/2008 4:26:59 PM • VIA ASRock K7VM3... • Answered on Aug 31, 2008
VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09) Logo
37 questions posted
Top VIA Computers & Internet Experts
MegaByteMe
MegaByteMe
Aron
Steve Pack
Steve Pack
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • VIA Computers & Internet
Most Popular Question
need drivers vga graphics adapter dell
  • Computers & Internet
