20 Most Recent
Pele Sports 1962 Redeemer HG - Black/Vibrant Orange 12 Questions & Answers
What is the best steel for a hunting knife?
Right now the best steel as far as stainless steel is S35VN stainless steel. It surpasses the S30V steel. But if you want the best carbon steel, personally I would go with D2 steel. It is such a good steel that it is considered a semi-stainless steel.
But to really help you out, it's not the type of steel that's the most important thing. It is the way the steel is heat tempered and hardened. If it is not properly heat treated and hardened, then the steel is worthless as far as knives go. If the HRC is too high for the type of steel/ stainless steel, then the blade will be brittle and chip or break easier.
If the steel's HRC aka Rockwell hardness is too low, then it will easily bend and will not hold an edge well at all.
Each steel and stainless steel have their own HRC tolerance level Going above or below its HRC tolerance makes for a bad knife blade.
9/16/2022 6:40:45 AM •
Hunting
Answered
on Sep 16, 2022
Pusha
? What is your Question?
2/24/2019 7:41:26 PM •
Hunting
Answered
on Feb 24, 2019
Game bags
Yes use them
2/24/2019 7:12:18 PM •
Hunting
Answered
on Feb 24, 2019
Khc1039w
Go to a sports/hunting store and ask for a catalog.
2/12/2019 6:06:10 PM •
Hunting
Answered
on Feb 12, 2019
How can i open edgars account
This is a little late, but go into Edgars if one is close and ask for an application. If there is not one near you then find one on line and ask for one.
2/12/2019 5:57:08 PM •
Hunting
Answered
on Feb 12, 2019
Rotating tree stand won't turn
The problem depends on the type of stand that you have. I suppose that because you are on the hunting site that your stand is some type of hunting stand. Is it a seat mounted that rotates or a some other type of setup? If you have a seat that rotates manually, then look for the pivot or rotating part of the stand where the stand and chair connect. There should be a bushing or bearing that is seized and needs some lubrication.
2/12/2019 5:52:33 PM •
Hunting
Answered
on Feb 12, 2019
