20 Most Recent
Alpine CDA-9825 CD Player Questions & Answers
How do i tern the
automatic. aftermarket radios have small built in amplifiers and the fans are there to keep them cool
Stereo sounds stops but stereo stays on
This is due to a short in one of the speakers Or a blown speaker making it short out and stereo will stopped outputting any sound to prevent damage to the stereo.
I am hooking up the stereo and I know I have power...
The yellow wire is the constant wire, you need to find the battery + wire which will be red and hooked that to your deck, the red wire is the main 12v wire and the yellow wire is there just to use a little bit of power to keep the memory i yur deck, i.e. the time, cd position stuff like that
How do we set the clock
1 In the Clock priority mode, press and hold the DISP/
TITLE button for at least 3 seconds while the time is
displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the
time indication is blinking.
3 When the hour has been adjusted, press the Rotary
encoder.
4 Turn the Rotary encoder to adjust the minutes while
the time indication is blinking. The time is automatically
set 5 seconds after the minute adjustment. The time
can also be manually set by pressing the Rotary
encoder.
Have a alpine cda-9825 head
turn your volume down before you switch what maybe happening is that you amp is over heating and going into "safe mode" and turning itself off. I have seen that happen before because the radio signal is " loader " then the cd. If it's still not giving you any love you may have a short somewhere. what wire do you have the remote to your amp hooked to?
Let me know what happens, Good luck
Mark
C.C. Motorsports
I need to know what cable goes to the fm system
there is no colored cable for the fm system.
There should be a wire that comes out of your car to the back of your cd player.
all you do is hook that one up to the antenna connector on the back of your new cd player
I'm not getting the correct output from my door
Definitely possible. To make sure it's not your speakers switch the wiring for them. Basically change it so the side that is working now is connected to the speaker that is not working. If it works then it is your Deck.
Alpine car stereo model #CDA 9825
you could remove the radio from the socket..............
yes maybe the fuse fot blown
but then it wont work at any time
my guess is that may be some internal wire got burnt
I need a Manual for a Alpine Vie-x077 in English and also anyone know why it keeps saying the disc needs to be ejected but it won't
- Mechanical Issue: There might be a mechanical problem with the disc drive or the eject mechanism. It's possible that a part is jammed or not functioning correctly.
- Dirty or Damaged Disc: If the disc is dirty, scratched, or damaged, the player may have difficulty reading it and thus not ejecting it properly.
- System Error: There could be an internal error within the player's software or firmware causing it to not recognize the disc properly or to malfunction when attempting to eject it.
- Power Issue: Sometimes, power-related issues can affect the functionality of electronic devices. Ensure that the player is receiving adequate power and there are no loose connections.
Here are some troubleshooting steps you can try:
- Turn off the player and then turn it back on to see if it resolves the issue.
- Try ejecting the disc using the manual eject button (if available). This button is usually a small pinhole near the disc slot. You can insert a paperclip or a similarly sized object into the hole to manually eject the disc.
- If possible, try using a different disc to see if the problem persists. If other discs work fine, then the issue may be with the original disc.
- Check for any visible obstructions around the disc slot and remove them if present.
- If none of the above steps work, you may need to contact Alpine customer support for further assistance or consider taking the player to a qualified technician for repair.
My Alpine CDE-W235BT bluetooth has stopped working
Se o Bluetooth do seu Alpine CDE-W235BT parou de funcionar ap?s uma falha durante a atualiza??o, pode haver algumas etapas que voc? pode tentar para resolver o problema:
1. **Reinicie o Aparelho:**
- Desligue o r?dio por alguns minutos e ligue-o novamente. Isso pode reiniciar o sistema e resolver problemas temporariamente.
2. **Restaurar as configura??es de f?brica:**
- Consulte o manual do usu?rio para descobrir como realizar uma restaura??o das configura??es de f?brica em seu Alpine CDE-W235BT. Isso pode resolver problemas causados por configura??es incorretas.
3. **Verifique a vers?o do firmware:**
- Se poss?vel, verifique a vers?o do firmware do seu Alpine CDE-W235BT. Se houver uma vers?o mais recente dispon?vel, considere atualizar novamente o firmware, seguindo rigorosamente as instru??es do fabricante.
4. **Remova Dispositivos Pareados:**
- No menu Bluetooth do r?dio, remova todos os dispositivos pareados anteriormente e, em seguida, tente parar novamente. ?s vezes, problemas de conectividade podem ser resolvidos removendo e pareando novamente os dispositivos.
5. **Atualiza??es de Software:**
- Verifique se h? atualiza??es de software dispon?veis para o seu Alpine CDE-W235BT no site do fabricante. Caso existam, siga atentamente as instru??es para realizar a atualiza??o.
6. **Contate o Suporte T?cnico:**
- Se as solu??es acima n?o resolverem o problema, entre em contato com o suporte t?cnico da Alpine. Eles podem fornecer assist?ncia espec?fica para o seu modelo e orienta??es adicionais para resolver o problema.
Lembre-se de que mexer no firmware e nas configura??es do dispositivo envolve riscos, e ? sempre recomend?vel seguir as instru??es fornecidas pelo fabricante para evitar danos permanentes ao aparelho. Se voc? n?o se sente confort?vel fazendo isso por conta pr?pria, procurar ajuda profissional pode ser uma op??o.
Alpine tdm 7543. Is this a model that can switch from green to red lighting?
After researching, it appears that there is no direct evidence suggesting that the Alpine TDM 7543 stereo unit has the ability to switch from green to red lighting. This is an older unit and specific information can be challenging to find. Your best option to get a definitive answer may be to directly contact Alpine's customer service or refer to the original instruction manual.
