20 Most Recent Alpine CDA-9855 CD Player Questions & Answers
I bought a ALPINE CDA 9855R and it keeps making a bleeping sound. Stereo consistently beeps and is annoying. how do I stop this
open menu on unit use the home button to turn beep sound on or off;;
3/3/2019 5:26:19 AM • Alpine CDA-9855... • Answered on Mar 03, 2019
How to change tuner to
It will only tune into odd numbered stations because US radio station only broadcast in odd number stations (ex 95.5,95.7,96.3). You can change the area. Area 1 is North America, Area 2 is other areas. Press "Menu"->"Setup"->"Tuner"->"Tuner Area", then select 1 or 2. After setting, press and hold "Menu" for at least 2 seconds. This may give you the frequency you are looking for.
1/29/2014 1:50:38 PM • Alpine CDA-9855... • Answered on Jan 29, 2014
I have a CDA-9855 Alpine
it sounds like you have the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) turning on an external amplifier in your rover. the antenna remote wire turns off when you leave tuner mode.
12/24/2013 6:49:10 AM • Alpine CDA-9855... • Answered on Dec 24, 2013
manual
0answers
0answers
Need manual so i know which button are for what
You may download a copy of the manual here.
10/22/2012 5:15:20 PM • Alpine CDA-9855... • Answered on Oct 22, 2012
Alpine CDA-9885 has no sound to rear speakers when playing a CD. Works OK when in tuner mode?? What up??
Are you running your rear speaker through an amplifier? If so, you are probably using the blue wire (power antenna remote turn on) instead of the blue/white wire (amp remote turn on). The blue wire turns off when leaving tuner mode, thus turning off the amplifier.
7/11/2012 1:23:03 AM • Alpine CDA-9855... • Answered on Jul 11, 2012
How do i set the facure to stay on illuminated
try cleaning the contacts on the face and subpanel with a q-tip and rubbing alcohol or a toothbrush and rubbing alcohol.
9/21/2011 4:02:06 PM • Alpine CDA-9855... • Answered on Sep 21, 2011
IPod? Operation
yep it sucks but you have to purchase the KCA-420,but its worth it.
8/6/2011 10:23:34 PM • Alpine CDA-9855... • Answered on Aug 06, 2011
I have a alpine 9853 that wont turn on. I replaced
the cd player thinks it is being stolen you need to have it decoded it cant be dont without a machine alpine must do it
1/19/2011 7:48:33 PM • Alpine CDA-9855... • Answered on Jan 19, 2011
0answers
Hi i have an alpine
he may need an adaptor to run to the infinity amp. it should be available at any good car audio store.
8/16/2010 11:01:23 PM • Alpine CDA-9855... • Answered on Aug 16, 2010
HOW TO PLUG IN AMP N SUBS
Connect the line out (+) and (-) to your subs.
6/7/2010 6:28:35 PM • Alpine CDA-9855... • Answered on Jun 07, 2010
Display want stay on screen
Adjust the timeing in settings.
5/30/2010 5:31:26 AM • Alpine CDA-9855... • Answered on May 30, 2010
ALPINE CDA-9853R car audio scheme
contact 91 22 9867607580 you will get any manual
5/28/2010 1:06:31 PM • Alpine CDA-9855... • Answered on May 28, 2010
2answers
Alpine cda-9855r with no display
when mine does that it is down to the connection of the face to the head unit, push it firmer or remove and replace. it may be that the connection is worn.
3/20/2010 11:35:50 AM • Alpine CDA-9855... • Answered on Mar 20, 2010
I have pluged a kca420i & ipod into my
Let's do some inexpensive troubleshooting. At the amp switch the rca jacks and see if you still get sound. If you get sound out of the left speaker then the right side output needs to be repaired. But if you get sound out out of the right speaker only then you have a problem with the preout of the stereo and the stereo will need to be repaired. Hope this helps.
1/8/2010 6:22:42 PM • Alpine CDA-9855... • Answered on Jan 08, 2010
Alpine CDA-9855 CD Player Logo
45 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
need manual know button
  • Car Audio & Video
