20 Most Recent
HP Envy 4500 e-All-In-One Printer, Copier, Scanner Questions & Answers
How to enlarge print when copying on Envy 4500
To enlarge the print when copying on the HP Envy 4500, you can adjust the zoom or scaling settings in the printer software. Here are the steps to follow:
1. Load the document or photo that you want to copy onto the scanner bed.
2. On the printer control panel, press the Copy button.
3. Use the arrow buttons to navigate to the Zoom or Scaling option and press OK.
4. Use the arrow buttons to select the percentage by which you want to enlarge the print. You may be able to choose from a list of preset options (such as 125%, 150%, or 200%), or you may be able to enter a custom percentage.
5. Press OK to apply the changes and start the copy job.
If you're using the printer software on your computer to control the copy job, you may need to follow slightly different steps depending on your operating system and the version of the software you're using. However, the basic process should be similar. Look for options related to zoom, scaling, or print size, and adjust the settings as needed to achieve the desired level of enlargement.
HP Envy 4500 series printer has stopped printing, paper comes out blank. It does scan.
I would try looking at the settings, on your ipad or laptop that tell your wireless printer what to do, maybe something has been changed accidentally, and needs to be reset. Also if your broadband configuration has been altered this can cause problems. If you have a laptop try connecting by cable to the printer and then see if it prints OK! if if does it is the broadband as said, and will need to be reinstalled. Good luck.
Can I print small photos Using 4x6 photo paper??
you can print more photos per page but it requires you to set up the page and the number of photos on the page
one of your photo shop programs will have that ability and it will take some trial and error to get the right results
basically it will work like this select a photo and insert it on to a page
select another photo and insert it onto the same page next to the first one and so on until you have a page full
the page can be sectioned into squares as well
when you have what you want go to print preview and if that is working then print
after that use a sliding paper cutter to cut the photos from the page
