20 Most Recent
Wacom Cintiq 15X Graphic Tablet Questions & Answers
Wacom cintiq tablet video isnt working
If you have Windows Xp, try right-clicking on your screen, click 'Propetries', then click the "Settings" Tab, then there will be a picture of two screens - one has a number 1 on it, and the other has number 2. Click on number 2 and raise the "color quality" from Lowest (8 bit) to Highest (32 bit). Also, take the "Screen resolution" up to about less than half way. Then click "Apply". You will get a prompt asking if you really want to do this, so just hit yes. Your screen should turn on immediately after that.Ps. After you do this, hit "Identify". There should be a giant number 1 on your computer, and a giant number 2 on your tablet.
Worked fine, now all of a sudden it no sync/go to sleep
I had this problem. Tried everything. Then I hooked the tablet up as my main monitor and adjusted the resolution. Also adjusted the resolution on the other monitor to the same. Then switched them back to normal and it worked.
My Cintiq 21ux is not recognized as a 2nd monitor
HI, I've had a similar problem. This solved it for me. Connect the cintiq first to a dvi to vga adapter, then connect that to apples vga to mini display port adapter.
worked for me so I'll keep my fingers crossed for you.
We plug in power cord
Try this: unplug the signal cable on the tablet, wait 15 seconds and plug it back. If the plugging of the cable isn't detected in less than 5 seconds then the tablet is faulty and you will have to return it.
Purchased used cintiq - we
If the pen is working like a mouse then it is fine. All you have to do is to open any graphics program, ie, paint in Windows, and start drawing with the pen. Or open Word and you can sign your name on the document.
I just got a cintiq
I had this same problem and just had to go into my system preferences on the imac and select display and then select/check the mirror monitors and now it is on sync-hope that helps!
After I did that though my color is off on the cintiq so I am looking for suggestions on how to fix it as the calibration did not fix the problem.
