20 Most Recent
Bang and Olufsen Beocenter 9300 Shelf System Questions & Answers
I HAVE A
I am not familiar with the model but a high quality turntable and tonearm needs special care.
The turntable should be adjusted to be as level as possible - the classic method uses a circular "spirit" level that has a blob of mercury instead of a bubble.
The tone arm can be moved manually but great care must be exercised especially if it is fluid damped, though it is better not to if the mechanism is functioning.
It is important the stylus tip is in good condition and the playing weight is adjusted to the required value using a stylus balance.
The correct playing weight is specified by the cartridge manufacturer and the adjustment method will be described in the instruction manual.
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
I have a set of
Have you tried this set up before.?The Beocenter can't draw the energy to the beolab penta mk1.
Check out the output watts with Beocenter it is lesser than beolab.So nomally it wont work.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
