20 Most Recent Jack Lalanne s Pro Stainless Steel Power Juicer Questions & Answers
auto parts stores usually have assorted ones. Take the old one out and have them compare
Jack Lalanne s... | Answered on Aug 27, 2014
Designing kitchen is a precise art. I suggest you to take a look about glass splashbacks and worktops which gives your kitchen a stunning look. Give a click to CreoGlass Design to know more about kitchen glass splashbacks designs for your kitchen.
Hardware &... | Answered Yesterday
Google (brand)(TM1627L)(manual) without parens for instructions.
Hardware &... | Answered 3 days ago
I had a similar unit. The solution is in the programming. Read instructions carefully
Hardware &... | Answered on Oct 04, 2019
does your wiring look like what is shown in the instruction papers?
From your description, it does not sound like it. There is no white wire attached to the switch.
What type of bulbs are you connecting to? These require bulbs that can pass small amounts of current when off == incandescents and florescent. They may not work with LEDs.
I am not a heating expert so take this with a grain of salt.
IMHO, a sooty burning oil burner (which kerosene is used in) is due to too much fuel or too little air. An oil burner consumes oxygen, therefore ventilation is required. A direct vent supplies makeup air and provides and exhaust path. Kerosene comes in a couple of different grades. K2 is generally used for heating.
SO, insure you have the correct type kerosene. Inspect your direct vent to insure it is drawing in air from the outside easily. Insure your control is not supplying too much kerosene.
The flame should not be red - that is a definite indication of too little air/too much fuel. If it is very blue, it may get blown out. Your manual should show you the perfect flame color.
If you are smelling kerosene, that would be a good indicator that something is wrong with your direct vent. Any leak between the exhaust section and the makeup air section will cause this. Reinstall the vent and insure the directions are followed. Moving the vent after installation is perfect for breaking the seals and creating the problem. Have you had any earthquakes lately?
AND WE DO NOT KNOW WHAT YOU HAVE EITHER .
You might be able to adjust the glides. An easier way would be to make the cabinet tilt slightly rearward by shimming the front of the cabinet at the bottom.
Hardware &... | Answered on Oct 03, 2019
Jack Lalanne s Pro Stainless Steel Power Juicer Logo
2 questions posted
Top Jack Lalanne Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Are you a Jack Lalanne Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Jack Lalanne Hardware & Accessories
Most Popular Question
missing o ring find one
  • Hardware & Accessories
