20 Most Recent Saeco Odea Giro Espresso Machine & Coffee Maker Questions & Answers
All lights are functioning but coffee is going directly into the dispenser. We tried to clean it but still same issue. Will it need a full repair or can we fix it from home
Try to put grinder (***** on top near cafe beans more to the right) on more rough. Choose less strong cafe and put cafe foam valve (if you have it) off (full left). If problem persist, open the dispensing mechanism box, take all out, there is water dispensing pipe in the back (unscrew screws), take it out and clean it (the pipe should be hollow 5mm wide, it can take a day in vinegar to dissolve and/or water pressure and tiny *****-er to clean it). Do the descaling&rinsing. Try not to play around much as it might burn the pump.
3/31/2016 11:37:17 AM • Saeco Odea Giro... • Answered on Mar 31, 2016
Why doesn't it turn on?
maybe somthing broke
4/6/2016 8:25:57 PM • Saeco ODEA... • Answered on Apr 06, 2016
No power, broken wire, bad connection, blown fuse, bad heating element, bad switch, ad infinitum.
2/25/2016 3:03:40 AM • Saeco ODEA... • Answered on Feb 25, 2016
The coffee grounds lihgt and the descale light flash after I push the brew button on my seaco odea giro.
The sensor inside the water container has either mineral build-up (scale) or a bit of coffee grounds stuck to it.
  1. Run a cycle with a retail coffee maker "cleaner solution" to clean the water reservoir, or let vinegar soak inside 5+ hrs.
  2. In both cases, turn unit upside down and power wash reservoir 2X to dislodge deposits that have loosened during the soak.
  3. Make sure to run a few cycles of plain water thru coffee maker before making the next batch of coffee.
12/6/2015 9:16:57 AM • Saeco ODEA... • Answered on Dec 06, 2015
How do I fix a Saeco Odea Go coffee maker with a gri nder problem
hi, This is shrikant shinde from Mumbai india .we specialist in coffee machine repairing.tell me i will help.send me pic of machine while give error. Whis is the exact problem with grinder tell. regards, Shrikant Shinde Yogishri Engineering +91-8425830001
1/28/2015 7:13:36 PM • Saeco ODEA... • Answered on Jan 28, 2015
Steamer not working
Try this push in on the steam knob after it is turned on if that works the steam valve assembly needs to be replaced.
9/12/2014 6:50:48 PM • Saeco ODEA... • Answered on Sep 12, 2014
Saeco odea eror
Alarm light: • permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the grounds drawer is full. • on and slowly flashing (one or more events): signals that the Brew Group is not inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not inserted or the service door is open. • on and quickly flashing : signals the need to prime the water circuit.
5/6/2014 6:07:48 PM • Saeco ODEA... • Answered on May 06, 2014
After descaling the coffe is no more strong
make the grinder more fine
11/29/2013 10:13:28 PM • Saeco ODEA... • Answered on Nov 29, 2013
0answers
When starting to grind, my excelsis saeco push open the service door
Make sure the containers are tightly in place and check the door sensors ( the magnetic sensors may need replacing). Also, consider trying to completely power off the machine, wait a few minutes, and start it back up.
2/7/2024 3:04:11 PM • Saeco Coffee... • Answered on Feb 07, 2024
2answers
Saeco Odea Plus Flashing rapidly: "Ventilate the water system" almost at every turning on?
For some reason, people don't think too often about how dirty the ventilation system is, even though it is essentially the air they breathe indoors. I think it is very important to at least sometimes do Ventilation smoke test, and also contact experienced specialists who can quickly and efficiently clean the ventilation. Such services are also provided by Grease Gone.
12/25/2023 2:49:14 PM • Saeco Coffee... • Answered on Dec 25, 2023
2answers
Saeco Gran Baristo has E05 error. Restarting doesn't resolve the error.
hi you have problem in water circuit ,either block steam boiler or one of tubes in or out , also can be electric valve if there is . Any case you have to open the machine and find out regards Guy
11/1/2023 2:17:23 PM • Saeco Coffee... • Answered on Nov 01, 2023
Saeco Odea Giro Espresso Machine & Coffee Maker Logo
Popular Tags
4 questions posted
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
ODEA Saeco
  • ODEA Saeco
Most Popular Question
all lights functioning but coffee going
  • Coffee Makers & Espresso Machines
