20 Most Recent
Samsung DVD-C350 DVD Player Questions & Answers
My samsung ht c350 wont
Found out how to solve this problem, as it has put a child lock on the device, try holding the Stop button on the remote for five seconds. This resets the device, then turn it back on and it will go through inital setup and then try oepning the tray.
Andy
Unit model D-C350/XSA only opens region 4 need to
When I was with Samsung NZ, the following was how we multizoned our DVD (Region 4) players:
1. Turn on your player, but ensure no disc in machine - screen should show "No Disc"
2. Turn on your TV and select your DVD input (as if you were to watch your DVD).
Using your factory supplied remote, press the following buttons:
3. Press the Repeat (or Repeat A-B) button
4. Press the following button sequence: 7, 6, 8, 8, 4, 9 (you should see the number '9' appear on screen - this means 'Region Free').
5. Press the Open/Close button (to open the tray)
6. Press the Open/Close button again (to close the tray)
7. Press Power OFF (to shut down your DVD player)
8. Press Power ON (to turn on your DVD player)
9. Insert Region 2 disc and wait (up to 1min) for firmware to respond and read your disc
If this fails, try procedure again, except for Step 4: change the last number (instead of 9) to '2'.
Let me know how you get on.
Cheers,
Scott
"If this has helped you, please be kind enough to leave a testimonial rating"
Just bought a Samsung DVD-C350.
If the remote itself is draining batteries at a rapid rate, the remote is probably of a defective design. The other possibility lies within the IRD controller circuit in the main unit - it is probably under-designed with low-grade inferior quality components (hence why it might be too weak to recognise the remote and/or the remote itself does work, but the unit's IRD is not detecting it). If you have tried to operate the unit with the remote close to it, and it still won't work, then the IRD controller is faulty (probably a manufacturing defect) - the main IC and associated components behind this infra-red device are usually the cause of 'no remote' faults. This gives the user the illusion that their remote is dead when it is the receiver circuitry at fault. Unfortunately this is an expensive repair and is not economical for a budget unit.
Although I am aware of various appliances and some of their stock problems, along with advancing technology, I am not completely sure of this model, however I would recommend that you visit the store you bought it from once more, and perhaps persuade them to exchange once more for a different brand/model of similar value and function. If that exchange involves a few extra dollars, so be it - you want it to work fully out of the box, so be aware of the price difference if necessary. You do not need to accept any offers of repairs on this one. See if you can get a better model.
Fingers crossed. Hopefully it will work out for you.
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
2 days ago
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
