20 Most Recent
MSI MEGABOOK S270 Notebook Questions & Answers
My MSI S270 works with external monitor but wont
one of the logical solutions is that you try to shut down the pc , remove battery and cables & then hold the power button for 8 secs. That way, you can determine if the circuitry of the monitor is functioning. Otherwise , you need to contact MSI for repair..
Need a driver for the
Try DRIVER MAGICIAN Lite.It's an amazing tool! A MUST-HAVE on any kind of computer!Here's the link:http://www.drivermagician.com/Lite.htm
Laptop no sound
Hi Scarlet,There could be many possibilities for this. Since its a new Laptop, nothing could have gone wrong with Hardware or Software. But could be some configurations. Please let me know the following details.What is the Operating system. If windows, do you see the speaker icon on the right side bottom of the screen. Check if its muted. Or increase the volume. Hope this solution worksRegards~SmokinJoe~
No screen display msi megabook s260
If you have a desktop monitor available try hooking your laptop up to
that. if you get a display on your desktop monitor then that means your
laptop screen needs replacing. If you get no display on your desktop
monitor then that means the GPU chip in your laptop has gone bad.
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver:
1. Find your graphics card model. Note down the model number.
2. Go to MSI's website.
3. Look for the support or downloads tab and click on it.
4. Use the search or menu options to find drivers for your specific graphics card model.
5. Download the driver package.
6. Run the installer file once the download is complete.
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
- On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
- On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
- Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
- On your Fire Stick, select your laptop from the list of available devices.
- On your laptop, click "Pair" when prompted to complete the pairing process.
- Once connected, you should be able to stream content from your Fire Stick to your laptop.
