20 Most Recent Acer Aspire TimelineX 5820T-5951 Notebook Questions & Answers
Aspire 5820t reinstalled win7 home prem 64bit,
You should first check if in your Device Manager your Network Card is being recognized, and make sure there is no errors (a yellow triangle would be displayed). If it is there, you can try uninstalling and reinstalling the drivers. You can also go into your BIOS setup when starting up the computer, and make sure it's enabled. If none of this works, to get your WIFI Fob working, you probably need to disable your Network Card first in the BIOS before your Fob will work. Hope this helps.
9/7/2017 3:38:11 PM • Acer Aspire... • Answered on Sep 07, 2017
Hi I have an acer imeline 5820t.Normally i connect wireless,but this morning i tried to connect and it says connected but when i try to go online it says NOT CONNECCTED,tried trobleshooter ,but that s
try going to dos prompt or command prompt TYpe in config/renew press entershttp://www.thewindowsclub.com/reset-tcp-ip-internet-protocol If it is windows 8 it could be a bug that stops the http protocol this means the internet browser won't load up the page . http://support.microsoft.com/kb/299357 http://www.thewindowsclub.com/reset-tcp-ip-internet-protocol the usual symptom you can ping the WI Fi Router at the dos prompt but the internet Browser Won't connect
3/3/2015 11:55:16 AM • Acer Aspire... • Answered on Mar 03, 2015
Power board diagram
I may be able to better help you if you could tell me what you are looking for on the motherboard, or what you are trying to fix on it.
8/3/2014 9:38:26 PM • Acer Aspire... • Answered on Aug 03, 2014
Im looking forAcer Aspire 5820T Windows 7 32-bit drivers
http://us.acer.com/ac/en/US/content/drivers then you choose product model.... then OS.... then driver you need
3/26/2014 3:16:32 PM • Acer Aspire... • Answered on Mar 26, 2014
Screen colour change
Faulty wiring
1/16/2014 6:43:42 PM • Acer Aspire... • Answered on Jan 16, 2014
Removing battery acer timeline
Depends on the laptop model, some of them have a lock that you have to press, some have multiple switches.There is two small switches on the bottom, opposite sides of the battery. One you have to toggle and the other just hold while remove the battery.(But it depends on the model...)***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
4/3/2013 9:13:31 AM • Acer Aspire... • Answered on Apr 03, 2013
Where is the sd card slot located
The SD card slot is located in the front of the laptop, when closed, on the left side of the front on the keyboard (BASE) section, there is writing that states, SD. Here is where you can get the quick start guide that helps with all the hardware ports and layout of the laptop. Under documents.http://us.acer.com/ac/en/US/content/drivers
4/1/2013 4:26:23 PM • Acer Aspire... • Answered on Apr 01, 2013
2answers
How can I get a Blu-Ray disc reader and writer?
They are not like a 3.5 hard drive or a 5.25 dvd rom for PC which are a national standard. For the most part there are two differences in height. One is a slimline, one is a super slimline. I have seen people who have the rom sticking out because it was made for the company. So what you have to do is remove it and measure it. Now comes the part of finding one, then you have to make sure the dimensions, and the interface are the same, most are old IDE. Very new is "usually' Sata.This is why you have to remove it, put it back if you need to use it, then search.Now it's not like a dvd rom 5.25 where almost everyone sells them.The best thing is to do a search, say you find it's a slim, Sata interface.So you search, laptop dvd blu ray internal slimline, this is just an example. You can start at a place called tigerdirect, and Ebay. Most everyone will tell you to go external, if you mess up you wasted all the money. Not easy to remove, it's not like I can explain how to dissemble it here. Some are a nightmare to pull out. Then there are MFG that don't give you any tech info or a diagram so you end up figuring it out.Most people who can do this, wouldn't be posting this question, they would know what to do.Good luck, and if you have problems, remember it's not my fault, as I don't recommend you do it.
4/1/2013 4:07:00 PM • Acer Aspire... • Answered on Apr 01, 2013
Acer 5820T quit while using and won't restart
Take out the battery and replace after some mins. If this doesn't work, remove the ram and place it back
1/30/2013 5:04:17 PM • Acer Aspire... • Answered on Jan 30, 2013
Acer Aspire wont clone display on monitor
It is very possible, software not included, it happens like microsoft and their new progs, somehow they miss old friends of until we complain.Try a download update.
1/29/2013 9:18:39 PM • Acer Aspire... • Answered on Jan 29, 2013
Acer Aspire 5820T Pc Notebook - Its not detecting the usb drivers. No usb ports work and neither does the Web Cam. Showing as Unknown Device under the usb devices.
I would guess the drivers are either not installed, or the wrong ones are installed. Go to the Acer website and select your model and download the current drivers from there and install.
9/26/2012 4:06:42 PM • Acer Aspire... • Answered on Sep 26, 2012
Bluetooth
there should be a button if not then your laptop dosent support bluetooth
6/16/2012 10:54:21 AM • Acer Aspire... • Answered on Jun 16, 2012
Acer Timeline X keyboard not typing what I want it to!
The laptop keyboard will need to be replaced, go to www.ebay.com Type: make and model of laptop and refine search to keyboard, but it would a good idea to hook external keyboard to make sure.
5/3/2012 1:47:48 AM • Acer Aspire... • Answered on May 03, 2012
I can't open my disc drive on my Acer Aspire 5820T without using a pin. How do I get the eject button to work?
I suggest that you can use the other method to eject: press start and go to my computer, select the disk drive and you should see an eject option in the menu bar.Remember that disk drives are subject to computer admin and do not respond quickly to a button press, especially if a disk process in taking place...
3/3/2012 8:05:24 PM • Acer Aspire... • Answered on Mar 03, 2012
2answers
I cant open the dvd
Look at the dvd tray there should be a small pin hole. Use a paper clip and push it into the pin hole and the dvd tray should pop open.
Please rate if this was helpful
3/3/2012 6:22:31 AM • Acer Aspire... • Answered on Mar 03, 2012
2answers
My laptop battery wont charge
You did not say how long you have had the computer. I can assume more than three months since they told you the battery was out of warranty. I am also not sure how "computer savvy" you are. Anything I say here is not meant to be insulting, so please do not tale any offense if I ask things or state things that seem overly obvious to you. Batteries are fickle things. They can sometimes act bad when they aren't. Example: When you first buy the machine, you are supposed to let it plugged in for at least 8-12 hours to ensure a full battery charge before using it on the battery. Some folks do this, many don't, either because they are impatient or don't take the time to read the instructions. An initial short charge can affect the entire battery's lifespan. Alos, the "battery meter" that shows charge level on most machines is an estimate of power in the battery, not necessarily the actual power in the battery. If you use the machine mostly on AC power, and don't use the battery often, then the battery gets only short, minimal discharge/charge cycles. This gives the battery and the "meter" a false sense of battery life which can result in the appearance of a weak or dead. battery. That being said, here id what you need to try to see if this can be salvaged. Unfortunately I am not Windows 7 savvy, but you can use the HELP feature to access and perform what I am saying and then attempt it. In the POWER MANAGEMENT area under the battery, you need to disable all warnings/shutdowns for the battery. This will ensure that the machine will run on the battery until the battery is so exhausted that the machine will simply stop running on its own (no safety margin). This will not harm the PC, the safety factor is there only so you don't lose data when running applications. Once you have disabled the auto-shutdown features, run the laptop on battery until it just quits. If the battery is in semi-good shape you may be surprised just how long that can be. I suggest watching a DVD, as the laser pulls a goodly amount of current. Once the battery is totally drained and the unit shuts off, plug the laptop back in and let it charge for 8-12 hours without using it. Restart the laptop, reset the POWER MANAGEMENT settings, and check the battery meter to see if any improvement has occurred. This process is referred to a "wiping the memory" of a battery and monitoring circuit. It can extend the battery operating time when the battery is used infrequently, or for very short periods of time. If, when trying to do this, the unit simply fails to power up, even after the POWER MANAGEMENT settings have been modified, then there is either a problem with the battery or the battery charging circuit in the machine.Hope this helps!
1/9/2012 5:02:09 AM • Acer Aspire... • Answered on Jan 09, 2012
I can not power on
Then your motherboard is problem, so take the motherboard to refix.
Note: Pin board can be refix (work on), while pinless board cannot not be repair.
Best regards.
6/28/2011 11:13:44 AM • Acer Aspire... • Answered on Jun 28, 2011
Acer Aspire TimelineX 5820T-5951 Notebook Logo
46 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
screen colour change
  • Computers & Internet
