20 Most Recent Sanyo VPC-X1250 Digital Camera Questions & Answers
I turn on my camara and then the lens makes a noise and it turns of right away,i charge the battery (fully) and it still turns off
maybe because you have a lens error trouble, Lens errors (system errors) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:wish you luck thanks
7/10/2014 11:30:22 PM • Sanyo VPC-X1250... • Answered on Jul 10, 2014
0answers
Cant turn on image stabilizer
When you are in recording menu, third line in the menu says Photo Stabilizer. But if tat one is grated out, that means it is not available. The manual never says anything about the stabiliser function. So if your camera allows you to stitch between stabiliser on or off, please let me know.
1/2/2014 10:13:23 PM • Sanyo VPC-X1250... • Answered on Jan 02, 2014
My laptop dont recognize the sanyo x1250
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
3/4/2012 7:15:45 PM • Sanyo VPC-X1250... • Answered on Mar 04, 2012
I have the Sanyo x1250 and it dropped with the len
Lens errors (system errors on Sanyo's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
10/17/2011 11:13:45 PM • Sanyo VPC-X1250... • Answered on Oct 17, 2011
How do you charge a
My wife got this for Christmas. The battery was installed from the manufacturer backwards. After looking inside I noticed 3 pins that matched the connections on the battery. Flipped the battery around and viola. I'd bet other people are having the same issue.
9/3/2011 4:50:17 AM • Sanyo VPC-X1250... • Answered on Sep 03, 2011
Usb device not recognized
Assuming a healthy camera battery, capable of holding a charge - try another cable / USB port / Computer first.
When it's same on all USB ports and a different computer, wiggle the USB connector on the camera carefully. If the connection is ok at some point, it's the camera USB port making bad connection.
7/4/2011 11:33:21 AM • Sanyo VPC-X1250... • Answered on Jul 04, 2011
How do you connect this camera to computer?
If you just want to get your pictures, consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
7/2/2011 7:13:22 PM • Sanyo VPC-X1250... • Answered on Jul 02, 2011
When i turn my camera
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
6/12/2011 2:28:50 PM • Sanyo VPC-X1250... • Answered on Jun 12, 2011
What does it mean when
try to reset your cammera settings to default
try to change memory card first.
try to format your memory card
6/5/2011 1:08:36 AM • Sanyo VPC-X1250... • Answered on Jun 05, 2011
I Dropped my Camera and
Lens Errors (a.k.a. "Zoom" and "System" errors) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth a try.
5/29/2011 5:16:31 PM • Sanyo VPC-X1250... • Answered on May 29, 2011
I have a Sanyo digital camera, model: VPC-X1250;
hi According to your information, somehow your camera has lens unit defective. Your local repair shop would charge around $ 35 to 75 depend on what really want to charge. Thanks and best regard!
5/24/2011 5:44:11 AM • Sanyo VPC-X1250... • Answered on May 24, 2011
I've plugged in my USB
Try NOT connecting your camera to your computer.
4/29/2011 4:55:12 PM • Sanyo VPC-X1250... • Answered on Apr 29, 2011
How do i replace the LCD screen on my sanyo
Replacing the LCD screen will not be cost effective. Compared to the cost of buying a new camera, it will cost more than it is worth.
3/1/2011 1:59:02 AM • Sanyo VPC-X1250... • Answered on Mar 01, 2011
My lens is stuck and
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
2/23/2011 4:33:39 AM • Sanyo VPC-X1250... • Answered on Feb 23, 2011
Sanyo VPC-X1250 Digital Camera Logo
Popular Tags
32 questions posted
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
View Most Popular
VPC Sanyo
  • VPC Sanyo
Most Popular Question
sanyo digital camera model vpc x1250
  • Cameras
