20 Most Recent Philips ProScreen 4750 Impact Multimedia Projector Questions & Answers
0answers
0answers
Service manual
Be the first to answer 2/11/2017 11:18:06 PM • Philips... • Posted on Feb 11, 2017Be the first to answer
Convergence phillips proscreen
The adjustment requires disassembling the projector. It's not really something that should be attempted in the field.
9/11/2014 12:58:04 AM • Philips... • Answered on Sep 11, 2014
2answers
No Power lights coming on and not even the fan
You can check inside or at bottom if there is any fuse box because your fuse might have gone..
10/23/2013 2:02:29 PM • Philips... • Answered on Oct 23, 2013
0answers
Shadow align
Be the first to answer 9/20/2013 6:15:25 AM • Philips... • Posted on Sep 20, 2013Be the first to answer
0answers
2answers
Color bars on both sides of picture
The Problem seems to be in the RGB Panels.
8/27/2010 12:47:19 AM • Philips... • Answered on Aug 27, 2010
It keeps overheating.
Is the fan set to run continuously? Go to the menu and see if it's set up to run. Also we have this problem with mounted projectors in our classrooms, we have to keep the room cool, and make sure the projector gets circulation of air.
Hope this helps.
11/18/2009 5:07:10 PM • Philips... • Answered on Nov 18, 2009
4answers
Green light on power up,fans run stays on for about one minute .
you have to reset the lamp timer this must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.If the problem still continue , you will need to replace the Ballast the lamp's power supply.
9/23/2009 7:10:07 PM • Philips... • Answered on Sep 23, 2009
The projector does not operate the
either it's overheated or needs a replacement bulb.Do not cover this unit with anything as it will prevent cooling down..
7/27/2009 11:16:47 AM • Philips... • Answered on Jul 27, 2009
I have a lc4750 proscan
most likely the mirror has moved or a lense has come out of its groove.
3/6/2009 3:00:33 PM • Philips... • Answered on Mar 06, 2009
Dark screen
Dear Bob,
Pls contact me at the soonest , i can solve this and i am willing to buy your unit.
[email protected]
jazz
3/4/2009 5:26:44 PM • Philips... • Answered on Mar 04, 2009
Fan not running
Dear Sir,
I am willing to buy over your Philip4750
pls contact me at the soonest [email protected]
regards
Mr Cheong
3/4/2009 5:23:54 PM • Philips... • Answered on Mar 04, 2009
3answers
Double image or shadow image
We recently had the same problem with our church projector and we too had just changed the lamp. I read somewhere while searching for an answer that if the cable input is loose it will cause double vision of the text. Sure enough, the cable was loose and after tightening the text cleared up immediatly.
3/4/2009 5:22:34 PM • Philips... • Answered on Mar 04, 2009
2answers
How do you get the
Hi there
There should be a lamp door at the bottom of the Projector that you have to unscrew before you will be able to take out the lamp.
1/9/2009 6:55:29 PM • Philips... • Answered on Jan 09, 2009
Philips ProScreen 4750 Impact Multimedia Projector Logo
Popular Tags
28 questions posted
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Aron
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Office Equipment & Supplies
Most Popular Question
keeps overheating
  • Office Equipment & Supplies
