Hello, Gary -
From what I have found about the Oreck MKT800 Vertical 5 Speed Hand Mixer, there is no "mixer blade" attachment for the appliance. The attachments for the mixer are:
- 2 beaters
- 2 whisks
- 2 dough hooks
You can see an image of the hand mixer with all 6 attachments here:
http://www.qvc.com/Oreck-Vertical-5-Speed-Hand-Mixer-with-Attachments.product.K6135.html
If you mean a replacement beater, whisk, or dough hook for your Oreck MKT800, so far, I have not found a source for those replacements.
Best wishes.
Question moved from Cars and Trucks.
Stand Mixers don't normally have belts and I don't believe this one does as I can't find spare belts. They are operated by nylon cogs that run in grease. The most likely reason is the she shear pin has sheared. This is a small pin like a nail that goes through a cog or shaft and shears if too much load is put on the mixer beater or dough hook. It often happens if you make bread and have the speed too high.
https://www.google.com/search?q=change+the+belt+in+a+Bodum+electric+mixer
You will need to get a qualified electronics technician to look at it. The issue could be anywhere on the circuit boards inside the mixer. Unless you know what you are doing don't try to repair it yourself as you could make the problem worse.
Spray some WD40 into the eject button. The wait 10 minutes and turn it upside down and spray WD40 down the side of the beaters Leave 10 minutes and try again/ If that doesn't work, you will need full disassembly
Push the head down before pressing the button on the mystery mixer. There is probably dough under the hook with it pressing the head up and is locking the catch.
You can pull out the dough around the dough hook to make it easier.
All questions need 'make model (what it is)', first 3 words please
All question need full 'make model (what it is)' please.
Duplicate question deleted. Press Refresh to see your question.
The only thing we know it that is made by Sunbeam and it MAY be a food mixer because that is the category it is posted to.
Look at what is there already.
It is black and greasy, it will be GP Graphite Grease.
If it is white and greasy, you can use white Lithium grease in spray or tube.
If it looks like normal oil, use 3 in One.
This is a service manual for a vintage mixer, it say to use a special grease, but from the description high temperature bearing grease would work.
https://studylib.net/doc/25985112/instructions-for-servicing-vintage-sunbeam-mixmasters
Nothing based on the the quoted words.
https://www.google.com/search?q=Sunbeam+power+unit+lubricant
Question edited for clarity and toss in some CAPS.
Remove the bowl. Push it upwards and turning at the same time to centre it. Or remove all the screws, drop it down, clean it and put it back.
https://www.google.com/search?q=thunderbird+arm-20+remove+guard
Could be anything, but could be the switch, the electronics board, motor windings, the carbon brushes or worn insulation somewhere. Odd that the plug fuse didn't blow. It needs electrical diagnosis to find out what went wrong.
