20 Most Recent
Roundup VCT-25 Toaster Questions & Answers
I am trying to reattaching the fencing...the
First make sure you have not taken out too many links of the chain. Start on one side so you can get it together. Once that one side is on I take a channel lock and grab the other side that needs to get connected and get get it as close as possible the I use a flat head screwdriver and work on it until it connects. Takes a little practice.
The back belt doesn't spin but the front belt
The four sprockets that the chain is resting on have gone bad. Pull the side cover off so you get access to the belt wrap and the chain itself. In the corners those sprockets need replacing. You will see they are very smooth. The drive chain may have came off so it will not spin the one side, but i doubt that.
Bread gets burn, to hot surface
Is the thermostat set correctly or is there an issue with the themostat? if the thermostat has gone bad try going to your local electrical shop and see if they can get a new thermostat
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
