20 Most Recent Vizio E470VA 47 in. HD-Ready LCD TV Questions & Answers
Turn on no pic no sound. Tried power downno luck. Pulled all wires off and then reattached. Any advice is appreciated. This tv was bought in 2010.
If totally dead check out power supply first. If some life then suspect your main board which deals with both audio and video.
11/22/2015 2:12:37 PM • Vizio E470VA 47... • Answered on Nov 22, 2015
Screen went gray no picture there is a light on the screen is not totaly black like when its off and the sound works is it worth fixing
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions. Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
3/9/2015 4:09:21 AM • Vizio E470VA 47... • Answered on Mar 09, 2015
0answers
VIZIO E470VA LCD HDTV Dish Hopper remote doesn't change volume
Try another remote code, many of the Dish or Cable TV remotes will have multiple codes for a particular brand of TV's
9/2/2012 12:40:16 AM • Vizio E470VA 47... • Answered on Sep 02, 2012
0answers
VIZIO E470VA LCD HDTV audio
Go to your On-screen Menu, go to settings, select audio, then select LIP SYNC. You can then adjust the amount of shift to synchronize the pix and the audio.
10/3/2011 9:15:11 PM • Vizio E470VA 47... • Answered on Oct 03, 2011
I need ro gins a
Replacement screens are available but it is more cost wise to replace the tv. The replacement screens are more than half the price of the unit. To find a replacement just google replacement screens for your set.
9/23/2011 5:57:56 AM • Vizio E470VA 47... • Answered on Sep 23, 2011
How to buy the screen
Following is Vizio parts dealer, please contact for required lcd screen...
Encompass Inc. 7060 State Road 84 #12 Fort Lauderdale FL 33317 Call: 954-723-9191 and 800-432-8542Thanks.
7/27/2011 8:17:38 PM • Vizio E470VA 47... • Answered on Jul 27, 2011
How to buy a replacement
Encompass Inc. 7060 State Road 84 #12 Fort Lauderdale FL 33317 Call: 954-723-9191 and 800-432-8542 Thanks.
7/27/2011 7:06:50 PM • Vizio E470VA 47... • Answered on Jul 27, 2011
2answers
Have vizio tv trying to hook audio out puts of
The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV.
Connect this cable to the back of the stereo receiver where it says "in" or "input".
Next take another cable and connect it from the stereo receiver output to the TV.
Daniel Busa
DISH Network Customer Service
2/19/2011 5:56:11 PM • Vizio E470VA 47... • Answered on Feb 19, 2011
I have a Vizio 47 inch LCD HDTV hooked to a Dish
Either unplug dish from tv or use the antenna side which is HD and program channels and see if volume the same, if not and is OK then it's your Dish bring your sound down or audio cables bad.
2/18/2011 10:53:15 PM • Vizio E470VA 47... • Answered on Feb 18, 2011
Vizio E470VA 47 in. HD-Ready LCD TV Logo
43 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
vizio e470va lcd hdtv dish hopper remote
  • Televison & Video
