20 Most Recent
Gateway MD7818u Notebook Questions & Answers
Driver md7818 wireless LAN for vista x32
http://support.gateway.com/us/en/product/default.aspx?tab=5&modelId=2366 This should be the drivers for your notebook. If not you will have to find it from the list of them here.
Forgot password
HiAre you running on a Windows Operating System platform?Hit F8 before the Notebook loads.Start Windows in safe mode.After loading Windows change or delete the passwords.Restart the machine.
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
MD781 battery wont charge...will run
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Battery is not charging
You maybe encountering errors such as plug in not charging or no battery detected. If so, there's a posibility that the problem is with the battery itself or the charger that you are using or worse, the DC port on the laptop. Here some steps for you to be able isolate the exact problem and which part is need to be replaced.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard or the Base Cover of the laptop itself.
Hope this will help...Thank you for using Fixya...
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
