20 Most Recent
Lanzar MNX250 2Channel Car Amp Questions & Answers
My lanzar mini max amp
first off you need to find out if your subs are 2 ,4,6 ohm . then check what ohm your amp will run if it is cutting off it's pulling to much power or it's over heating it.there are certen ways to hook up your subs.
I wanna supplied my Amplifier
- The battery is 12 volts and Ohms has nothing to do with your amp installation.
- Was the amp running and got hot? Many times an amp will go into "thermal mode" when used for an extended amount of time and need to cool down but I assume if you are trying to hook it up you were not using it.
- You need to check the ground wire real well. A loose ground will cause protect mode.
- Recheck the speaker wires and their connections. If they cross this to can cause protection mode.
- This is a 4 Ohm amp, are your speakers 4 ohm or lower> If not then you may be running to low of a load to your amplifier.
- I always remove everything from the amp first and power it on and then add wires and see where which connection throws the amp into power mode.
- Check the fuse as well but if the LED is on chances are your fuse is good.
- If you check all of the items I listed and the amp still goes into protect mode then your amp is bad.
Regards,
Tony
