20 Most Recent
kawasaki 1152 System Questions & Answers
Kawasaki 1152 retail price
recently (Dec 2007) purchased one on eBay for $20 plus $25 shipping (all the way across the US - - the shipping price was not out of line considering the size and distance).
No idea about original price.
Remote code
i need the remote codes for a kawasaki 1152 home theater system
No pic
Check the channel & Vido input
Cant See
do you have your tv set to the correct AV channel (for a scart connection) look at the Scart port on the TV (it should be numbered usually AV1..AV2..etc..)
Then you just need to switch to the appropriate AV channel on your TV
hope this helps.....
also check in your TV manual if the av socket you are connected to is an input or an output.
No sound when watching tv.
I think that all depends on how you have it set up, I'm guessing that you have the speakers connected to the DVD player, however I'm not sure if you have any audio cables running from the TV to the DVD (required if you want this for sound from your TV), I'd check your configuration, as it sounds like you have not got this set up right.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
