20 Most Recent
kawasaki 5-DVD Home Theater System - 1152 System Questions & Answers
User guide
http://www.18002526123.com/productdocuments/AV1000.pdf
pretty much same manual
How to you conect a kawasaki dvd to a hd tv
The best connection the kawasaki dvd has is a Component connection. This connection separates the Red, Green and Blue colour signals. Your HD TV should have a component input, just look for Red, Green and Blue RCA inputs labelled "Pr", "Pb", and "Y".You don't need the red, green, and blue colored RCA's specifically for this type of connection. The colors are there to help make it easier to connect. You can use any coloured RCA as long as you have the Pr on the DVD connected to the Pr on the TV and likewise for the other two connections. In addition to these connections you will need two more RCA's (Red and White) for the audio signal. You will need to connect the audio output of the DVD, to the audio input corresponding to the same Component Video input you are using for Video. This should be fairly self explanatory when looking at the DVD's and TV's connections at the back.
It does not play in
it may be connectet in HD. in HD for viedo three pins are connected so check the coulour in dvd and tv and connect it to the same colour
How do I get the
You might want to ponder why you would need audio from a TV in the first place if it originates elsewhere like a Cable Box. The fewer hops and interconnects a given signal takes on the way from the source to your ears, the better (and cheaper, too, as optical or HDMI cable is expensive). You COULD skip the TV entirely. Many don
One, can't find model number. Frankly, I need
You should find a sticker either at the back of the changer or on the bottom of it. You may also need the serial number that will probably be on that sticker also.
You can possibly find and read the manual on the web site of the maker.
Jim Hart
I cannot get the radio to work
When you say "radio" I'll assume you mean the FM radio; perhaps the AM does work? There is usually a coax connector for the FM radio antenna, perhaps one was included with the set, perhaps not. Make sure it is installed properly. Tune your radio to a frequency that is local and that you can get easily with other radios in the house and car. If its not picking up that station, check your settings on the unit to see if there is something preventing reception.
Progressive scan turned on - how do you turn it off?
I'm not very familiar with this namebrand on electronics, but they are all the same anyways.To check if this function is on, usually the player's lcd screen would have a "P", "PROGRESSIVE" or "P-SCAN" on it. First, make sure you remove all dvd's or cd's from the player, then look for a button on the remote, or the unit itself that say's "P-SCAN", "PROGRESSIVE" or "RESOLUTION", once you find it, push it, sometimes they would indicate the resolution on the player's lcd screen (480i, 480p,720p,1080i, 1080p), if not, on the tv itself. The resolution you are looking for is 480i for the type of cables you are using (composite RCA). Give it a try, and let me know how it goes...
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
