20 Most Recent
Samsung B2230HD LCD TV Questions & Answers
B2230HD TV STAND REMOVAL
First of all, thank you very much for choosing FIXYA today for your online technical support needs.See page 2-3 of the User's Manual for detailed instructions on how to remove the base stand on that monitor. But basically you just lay the monitor face down on a soft cloth so as not to damage the screen, and then just pull the base firmly straight out (downwards).
Here is a direct link to the ONLINE USER'S MANUAL for that model:http://downloadcenter.samsung.com/content/UM/201008/20100820090207453/BN59-01091B-01Eng.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
I can't hear anything when
Check the impedance of your headphone, which should match with the specified impedance in the user manual. The impedance of your headphone is very high.
sonsunny
It seems to forget its
Tries tv and the box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The box to upgraded it softwares.Tv should be working again.If still have the same problems.Take ur tv backcover aparts and disconnection of the tv side manual control board PCB wire connection plug in that have like Power,Channel - +,Volme - + and Menu so on buttons switches.Turn the tv on and see if tv funtions correctly If yes than the tv manual cotrol buttons PCB board have to be change.If the manual contol board is diconnected from the tv Tuner signal board and have the same problems.Than ur tv have a bigger problems,the tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual control PCB board or the tv Tuner signal boards for the replacement.
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
2 days ago
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
