20 Most Recent
PQI 500GB High Speed External H560 Ultra protection against vibration and shock complia USB 20 Hard Drive Questions & Answers
My external harddrivve wont work
You can try a program like this. http://www.piriform.com/recuva
If that does not work you will need data recovery help. This guy is good he does it remotely and only asks for donations. http://FreeDataRecovery.us
I connect the external disk
Go to disk management by right clicking on My Computer selecting Manage and you should see the drive there, right click on it and explore; this will give you access to the data on it.
This is a bug in Windows, to fix right click the device in Device Manager and remove then unplug and reboot the PC, once at a desktop plug the USB device into another port and all should be OK.
Hope this helps!!!
Driver memory stick
W 7
First, please disconnect all USB devices and then
perform the following steps:
Click "Start" button, type "devmgmt.msc"
(without quotation marks) in the "Search" bar and press "Enter".
Click "Continue" if necessary.
In Device Manager, double click to expand
"Universal Serial Bus controllers", right click on the Host
Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under
"Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will
reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select
properties device manager scroll down universal serial bus controllers
you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click
to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this
fails to fix the problem
Check the USB leads that attach to the motherboard
usually red white green black make sure they are securely seated and have no
dust build up on them dust will cause static and a lot of unforeseen problems
to a computer and its parts
if you need more help with
this or if i have missed the problem post a reply
My Computer suddenly does not
Check the following
- With the drive plugged in on powered on place your hand on it should be able to feel it vibrating (if no its not getting power or dead)
- If power and vibrating put your ear to the drive (repeating and squealing are bad, crunching sound is generally ok)
- With the drive plugged in and it sounds ok and it's vibrating[platters are spinning] right click on "Computer"/"My Computer" select manage > Disk Management, locate your drive if it is listed try to initialize it
- Right Click drive, properties, hardware tab, select drive, properties, volume tab and click populate
If it wont populate or doesn't show at all in storage manager at all either the drive itself is bad or the control in the external enclosure is bad. You can attempt to remove the drive from the enclosure and plug it in directly into the computer but this tends to void it's warranty. If the drive works however you can simply buy a new enclosure for about $12
Comment back if you need more assistance
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
